2MB/sec SMB transfer speed to TrueNAS Scale Storage
Try sudo -s then enter and enter your admin password then try again.
Thanks! That works.
Here is the output of one of the WD disks:
Summary
Model Family: Western Digital Green
Device Model: WDC WD20EARX-00PASB0
Serial Number: WD-WCAZAF139425
LU WWN Device Id: 5 0014ee 20720ea35
Firmware Version: 51.0AB51
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Device is: In smartctl database 7.3/5528
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Jul 13 19:32:53 2024 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (37500) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 361) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 172 170 021 Pre-fail Always - 6400
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 197
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 001 001 000 Old_age Always - 94539
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 191
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 83
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 117
194 Temperature_Celsius 0x0022 118 100 000 Old_age Always - 32
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
1 Short offline Completed without error 00% 28844 -
2 Short offline Completed without error 00% 28841 -
3 Short offline Completed without error 00% 28709 -
4 Short offline Completed without error 00% 28541 -
5 Short offline Completed without error 00% 15453 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
And here is the output of a Seagate drive:
Summary
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-1CH166
Serial Number: Z1F2NB4E
LU WWN Device Id: 5 000c50 050301a33
Firmware Version: CC44
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Jul 13 19:34:41 2024 CEST
See vendor-specific Attribute list for marginal Attributes.
been run.
data collection: ( 592) seconds.
command.
power-saving mode.
recommended polling time: ( 339) minutes.
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 182095872
3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 198
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 056 054 030 Pre-fail Always - 1189816967728
9 Power_On_Hours 0x0032 043 043 000 Old_age Always - 50549
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 123
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 097 000 Old_age Always - 0 1 121
189 High_Fly_Writes 0x003a 096 096 000 Old_age Always - 4
190 Airflow_Temperature_Cel 0x0022 062 043 045 Old_age Always In_the_past 38 (0 43 38 35 0)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 87
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1024
194 Temperature_Celsius 0x0022 038 057 000 Old_age Always - 38 (0 15 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 49192h+31m+51.454s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 17302167486
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 28937721516
No Errors Logged
1 Short offline Completed without error 00% 50390 -
2 Short offline Completed without error 00% 50387 -
3 Short offline Completed without error 00% 50255 -
4 Short offline Completed without error 00% 50087 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Apologies, I forgot that not everyone uses a normal shell as their shell. You can, if you want, change it to a basic shell in Credentials → Local Users and then edit the user of choice. All the ones ending with “sh” are shells.
The reason it couldn’t find sudo is because the binaries aren’t in the shell PATH’s, something I view as an oversight. You could fix that yourself either by changing your shell config/profile file or work around it by using the absolute path to the command you want to run.
Could you post the output of the full two other disks as well?
The one you posted an image of earlier wasn’t in the output you just posted.
and perhaps zpool status while you’re at it
Sure,
Disk 3:
Summary
1 Raw_Read_Error_Rate 0x000f 105 074 006 Pre-fail Always - 7453744
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 253
5 Reallocated_Sector_Ct 0x0033 100 099 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 060 052 030 Pre-fail Always - 1452094109357
9 Power_On_Hours 0x0032 014 014 000 Old_age Always - 76122
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 252
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 63405
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 6 7 9
190 Airflow_Temperature_Cel 0x0022 061 032 045 Old_age Always In_the_past 39 (6 96 39 35 0)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 69
193 Load_Cycle_Count 0x0032 089 089 000 Old_age Always - 22392
194 Temperature_Celsius 0x0022 039 068 000 Old_age Always - 39 (0 14 0 0 0)
197 Current_Pending_Sector 0x0012 100 074 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 074 000 Old_age Offline - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 51483h+51m+58.891s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 85638898724
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 121491805173
Disk 4:
Summary
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 2
3 Spin_Up_Time 0x0027 172 168 021 Pre-fail Always - 6391
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 192
9 Power_On_Hours 0x0032 001 001 000 Old_age Always - 94552
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 186
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 79
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 405
194 Temperature_Celsius 0x0022 115 100 000 Old_age Always - 35
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
Here it is:
Summary
pool: APPS
state: ONLINE
    NAME                                    STATE     READ WRITE CKSUM
    APPS                                    ONLINE       0     0     0
      f5520d42-7b42-45e7-9b04-13e1fe8d71a3  ONLINE       0     0     0
errors: No known data errors
pool: STORAGE
state: ONLINE
scan: scrub repaired 0B in 02:03:55 with 0 errors on Sun Jul 14 02:03:57 2024
    STORAGE                                   ONLINE       0     0     0
      raidz1-0                                ONLINE       0     0     0
        4a8d46dd-16dd-4cf3-a192-a6ed4f72c9fb  ONLINE       0     0     0
        df94f340-0527-402b-ad66-de7d7b209666  ONLINE       0     0     0
        fcf06a14-9944-4f35-85b9-18a880a4f624  ONLINE       0     0     0
        a6ec2541-7805-4f74-ab3b-128951e54798  ONLINE       0     0     0
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:15 with 0 errors on Sat Jul 13 03:45:17 2024
      sdf3      ONLINE       0     0     0
Can you show us the dataset properties from the UI want to check you haven’t turned sync on or dedupe.
Why today? Did you change anything? Did you set it up new?
Might not be related, but this has a hp 120i soft raid “controller”. I have been running it in SATA mode, which makes booting from the 5th sata port a bit of a hassle. It has worked without any problems over the years with Freenas, Core and Scale.
Some peope use the Intelligent Provisioning feature, which each disk being a single stripe, iirc. Generally using full raid controllers with zfs is recommended strongly against, but I do not think this is related to your problems, especially as it is not a “real” raid controller.
I can get some old disk from work, and use them to test things on Scale. My experience is, if the disk are that old, at some point they fail. Some have no smart errors, but produce zfs errors consistently, independed of cable etc. The same model of disk in the same “spot” works fine.
No, after installation I did not try copying files to it, until a couple days ago.
The onboard SATA controller is in AHCI mode, so no RAID configuration from the BIOS.
I have a separate SATA card installed with the boot drive (Crucial SSD) and a separate Samsung SSD is installed for the apps. So I’m not using the CD-ROM port at all.
Okay, so a new install, basically, not something failing that did work before?!
Just wrote a few larger files to my Gen8, no drop in bandwith.
What type/model of SATA card are you using? Always thought of adding one, but there is not much space in the case.
So drive 4 is the one from your earlier image, the one showing clear errors, but you still haven’t posted the full smartctl output. Without more details I will fall back on generic suggestions.
Run a long smart test. Ideally this should be setup to run regularly automatically, weekly or bi-weekly is a common recommendation.
Test your drives IO performance locally on the server with fio to see if they perform any better outside of SMB over the network. Make sure you read up on how to use it as incorrect fio usage can destroy the pool.
Good luck.
Thank you. I started a manual SMART test. It’ll take some time, but I will report back the results.
Hi neofusion,
I did long SMART tests and all came out with SUCCESS. I think it’s safe to say that the disks are not the culprit.
Any other ideas why my transfer rate to my STORAGE pool is so slow?
No, sorry.
Have you tried not running any of the apps - my gut feeling it’s a low memory issue. (I could be wrong.)
Riddle me this, from the same root command prompt:
 for disk in /dev/sd?; do; hdparm -W $disk; done
What you should see is a number of outputs similar to:
/dev/sda:
 write-caching =  1 (on)
/dev/sdb:
/dev/sdc:
/dev/sdd:
If, on the other hand, you see any drives with it off - then that’s potentially our problem.
Thank you, here is the output:
Write caching results
/dev/sda:
write-caching = 0 (off)
/dev/sdb:
/dev/sdc:
/dev/sdd:
/dev/sde:
write-caching = not supported
/dev/sdf:
/dev/sdg:
The first 4 disks are indeed my DATA storage…
Let’s do:
hdparm -W1 /dev/sda
hdparm -W1 /dev/sdb
hdparm -W1 /dev/sdc
hdparm -W1 /dev/sdd
And then re-run the for loop and check to make sure the setting stuck. If it did, try a big transfer again.
