Million of Checksum errors per day!
Hello people!!!
I arrived here after test and test and no way to find a solution!!!
My system has 4 pool:
  1. boot pool - 2 SSD Mirror
  2. Apps-pool - 2 ssd Mirror
  3. NVR-pool - 1 HDD
  4. Data-pool - 3 HDD Raid1
All discs are connected to LSI9300 (firmware updated). After about two years working, “Data Pool” start to appear Ckecksum errors, not a few, It increse about 1.000.000 per day. I make a lot of test, but no lack.
  1. I changed power wiring to a different PSU line, also I changed power cable
  2. I connected 3 discs direct to SATA motherboard ports
  3. I ran Memtest 24h - no error
I will change PSU this night but, as other discs has no errors, I dont think this will solve the problem…
What do you think about this problem…??? Has anyone has any idea???
Thanks for all!!!
Hi and welcome to the forums.
RAID-Z1 I guess?
What are the drives make/model/size?
Do the checksum errors appear across all three drives and are the amounts identical?
Hello!!!
Yes It is!! RAID Z1.
I have 3 WD Red 8TB
The ch ckeksum errors are almost the same in 3 hdds!!!
I dont know what more test that can I do!!!
When you moved the Data-pool from the HBA to the mobo did the checksum errors continue to climb in the same fashion or just stay the same?
Can you post the output of zpool status -v Data-pool
Also the output of smartctl -a /dev/sdx x being the last letter of your 3 WD drives.
Any chance that if you change the sata data connections from the HBA to different disks the errors follow? Could be port and/or cable issue if we’re lucky.
When I moved sata ports to mothwerboard, the errors continúe climbins as same rate.
3 smartctl are perfect. I Will post the data tonight.
Thanks for your help
Try out my set of flow charts which will help you identify the problem. Right now I can’t tell if the drives are bad, data cables are bad, power supply, etc. Could be a CPU as well, although I think that is rare. But a power supply issue could be causing it too.
Check out the link, grab a copy of the charts, jump through them. It should be simple to isolate this down some.
Also, provide your system specs, be specific. And what, if any, Apps are you running on TrueNAS, and is TrueNAS running on bare metal?
ok! Thank you very much joeschmuck! I will follow your link!!! I think I tested all components/cables/hardware except Power supply. As can I undestand, a faulty PSU, will make checksum errors on other disck, isn´t it??
I paste my results:
pool: data-pool
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
scan: scrub repaired 1.51G in 04:07:29 with 361 errors on Tue Feb 17 14:22:23 2026
    NAME                                      STATE     READ WRITE CKSUM
    data-pool                                 ONLINE       0     0     0
      raidz1-0                                ONLINE       0     0     0
        4ef5eff0-f52b-4058-bc4c-dbbdc4416f4b  ONLINE       0     0 1.17M
        f94d9511-92d3-433c-a9b1-92c2bbe6f6c8  ONLINE       0     0 1.29M
        2300bd5f-3068-4791-a5a4-3b8421c14229  ONLINE       0     0 1.24M
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-02_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-11_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-13_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-14_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-08_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-10_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-03_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-12_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-06_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-07_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-01-30_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-15_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-01-31_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-05_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-04_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-09_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    /mnt/data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-01-29_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
    data-pool/Backups/ReplicationBussionessGlobal/Data Bussiness Global/Shop012@auto-2026-02-01_00-00:/Backups Mysql Tienda/rpi_backup.img.gz
Smartctl:
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (40500) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 422) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3039) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   205   204   021    Pre-fail  Always       -       2725
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2898
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       12942
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   098   098   000    Old_age   Always       -       2871
192 Power-Off_Retract_Count 0x0032   197   197   000    Old_age   Always       -       2847
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       159
194 Temperature_Celsius     0x0022   103   088   000    Old_age   Always       -       44
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     12920         -
# 2  Short offline       Completed without error       00%     12896         -
# 3  Short offline       Completed without error       00%     12877         -
# 4  Short offline       Completed without error       00%     12854         -
# 5  Short offline       Completed without error       00%     12810         -
# 6  Short offline       Completed without error       00%     12786         -
# 7  Short offline       Completed without error       00%     12712         -
# 8  Short offline       Completed without error       00%     12688         -
# 9  Short offline       Completed without error       00%     12664         -
#10  Short offline       Completed without error       00%     12568         -
#11  Short offline       Completed without error       00%     12217         -
#12  Short offline       Completed without error       00%     12193         -
#13  Short offline       Completed without error       00%     12169         -
#14  Short offline       Completed without error       00%     12049         -
#15  Short offline       Completed without error       00%     12026         -
#16  Short offline       Completed without error       00%     12002         -
#17  Short offline       Completed without error       00%     11977         -
#18  Short offline       Completed without error       00%     11954         -
#19  Short offline       Completed without error       00%     11930         -
#20  Short offline       Completed without error       00%     11906         -
#21  Short offline       Completed without error       00%     11882         -
The above only provides legacy SMART information - try 'smartctl -x' for more
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.15-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red Plus
Device Model:     WDC WD40EFPX-68C6CN0
Serial Number:    WD-WX72D242NZCK
LU WWN Device Id: 5 0014ee 2164173dd
Firmware Version: 81.00A81
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/6083
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Feb 18 22:42:27 2026 CET
SMART support is: Enabled
                                        was never started.
                                        been run.
data collection:                (39840) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 414) minutes.
  3 Spin_Up_Time            0x0027   206   205   021    Pre-fail  Always       -       2675
  4 Start_Stop_Count        0x0032   089   089   000    Old_age   Always       -       11818
  9 Power_On_Hours          0x0032   090   090   000    Old_age   Always       -       7446
 12 Power_Cycle_Count       0x0032   089   089   000    Old_age   Always       -       11793
192 Power-Off_Retract_Count 0x0032   185   185   000    Old_age   Always       -       11779
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       305
194 Temperature_Celsius     0x0022   103   092   000    Old_age   Always       -       44
No Errors Logged
# 1  Short offline       Completed without error       00%      7424         -
# 2  Short offline       Completed without error       00%      7400         -
# 3  Short offline       Completed without error       00%      7378         -
# 4  Short offline       Completed without error       00%      7376         -
# 5  Short offline       Completed without error       00%      7125         -
# 6  Short offline       Completed without error       00%      7033         -
# 7  Short offline       Completed without error       00%      7009         -
# 8  Short offline       Completed without error       00%      6985         -
# 9  Short offline       Completed without error       00%      6961         -
#10  Short offline       Completed without error       00%      6937         -
#11  Short offline       Completed without error       00%      6913         -
#12  Short offline       Completed without error       00%      6889         -
#13  Short offline       Completed without error       00%      6865         -
#14  Short offline       Completed without error       00%      6841         -
#15  Short offline       Completed without error       00%      6817         -
#16  Extended offline    Completed without error       00%      6802         -
#17  Short offline       Completed without error       00%      6793         -
#18  Short offline       Completed without error       00%      6769         -
#19  Short offline       Completed without error       00%      6745         -
#20  Short offline       Completed without error       00%      6721         -
#21  Short offline       Completed without error       00%      6697         -
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
No Errors Logged
Thanks again!
Are you sure?
If the errors are climbing at 1 million per day, then after 3 days you should have over 3 million errors for each drive.
The errors reported by zpool status are cumulative, unless you reset them with zpool clear or run a scrub that finds no errors.
Yes, It is. I reseted then one day ago, when I test connecting SATA to motherboard ports. So, system is running about 30 hours and you can check how high are checksum errors….
I cant change PSU this night. I Hope It solve the problem….
***Checksum errors reset on reboot system too
Something to check:
  • are you spinning down your disks? 2 of them have 11k+ of start/stop count for 7k hour of power on, maybe im wrong but to me seems a bit odd
  • disks are properly cooled? The showed 44° Is not in the dangerous zone, but i suspect temps go higher
  • do you run only a long smart monthly? Better you try run a long now manually
Hello Oxyde!!!
  1. yes. I set Up on power management to 5 minutes, I think… It could be a problem???
  2. I have to install another fan, but the Max temp registered was 46 degree
  3. I Will run today and paste the results
About steps of Joeschmuck, I followed then. I think this is a very good and interesting job and very interesting guide to solve any disk problem!!! In my case, It cant solve my problems, because I cant stop my checksum errors!!!
Thanks again to all!!
IMHO a bit much aggressive. You are stressing a lot your disks
you really need it :smile:
Those 2 things, if not fixed, will kill your disks on long term… but not explain the errors.
Let’s wait your results
46° is perfectly fine.
Ran my at 55° for years without any problems.
For most HDDs, 5° to 50° or 60° is within vendor specs and perfectly fine.
The WD red in question here is rated up to 65°.
A cooler HDD might run slightly longer (there is no good scientific data backing up that claim though AFAIK, just a lot of people online parroting that claim or talking about their gut feeling), but it isn’t a cause to really worry.
Are these drives WD Red SMR drives?
Looks like 8TB WD Red were never SMR.
OK! I will change it to 60 minutes!
I just received today my new RM750x PSU. I will install it after lunch time! I’ll write again to update the results.
Thanks !
No luck with PSU Replacement!
Next step: mother+ram(change to ECC) + processor
This problem is making me crazy!
You’re reading 1 million blocks per day? What is your server doing?
Can you give the output of zpool status -v Data-pool then wait 1 hour and do it again? The number of errors should climb 40k.
An observation: Drive WD-WX72D242NZCK has a “Power Cycle Count” of 11,793. This is not a SLEEPING Drive issue, this is a power to the drive issue. You have a bad power connection.
I guess I should add this kind of scenario to the flowcharts, but it can’t be that common.
Once you fix the bad power connection, and the drive Power Cycle Count stops increasing, then you can fix the other errors. Please note that it could be a power cable or it could be a bad solder connection or failed electronics on the drive itself.
Once that is fixed, now address your file corruption issues.
Delete the files reported as corrupt by zpool status -v first. These files are not recoverable and are corrupt.
Next, after the files have been deleted, run zpool clear data-pool then zpool scrub data-pool.
Wait at least 1 hour so you have some data to work with and you can check the status again, see if the CKSUM is still zero and no new corrupt files occur. zpool status -v and hopefully things will look up.
@luiscaloto replaced the PSU and the errors continue for all 3 drives, not just 1 drive.
Presume you changed the power cables from the PSU to the drives also? (If using a modular PSU) ?
Did you also replace the SATA cables?
