Add NVMe to Single Disc
You’d have to supply the verbose option to see if that is indeed the other device.
lspci -v without the “grep”.
Ok, here we go:
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980 (prog-if 02 [NVM Express])
        Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller 980
        Flags: bus master, fast devsel, latency 0, IRQ 33
        Memory at fc900000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, MSI 00
        Capabilities: [b0] MSI-X: Enable+ Count=13 Masked-
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
        Capabilities: [158] Power Budgeting <?>
        Capabilities: [168] Secondary PCI Express
        Capabilities: [188] Latency Tolerance Reporting
        Capabilities: [190] L1 PM Substates
        Kernel driver in use: nvme
        Kernel modules: nvme
The other one:
08:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980 (prog-if 02 [NVM Express])
        Physical Slot: 0
        Flags: bus master, fast devsel, latency 0, IRQ 11
        Memory at fcf00000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [b0] MSI-X: Enable- Count=13 Masked-
Both take different IRQs - but i am still insecure, if those a different NVMEs.
Nowhere in the BIOS is there a RAID/AHCI option? (Don’t change anything yet! Just check.)
Is the server connected to a monitor and keyboard? Would it be possible to boot into an Ubuntu live ISO to see if it will show the device with nvme list?
There is such an option, but its still in AHCI, as far as i remember. And, i didnt go into the BIOS until today, to see, if the NVMe is detected there.
I will create an USB thumb for the linux live system and check.
A strange thing, which happened today was, i had a talk with my colleague on work and he sloppily mentioned “Why dont you take the card out, during the system runs and reseat it? Normally the ports are hotswap-able”
Did it as mentioned - the card was recognized and i was able, to add it to the pool as a mirror.
Might it be possible, that TrueNAS marked the whole port as “defective”? But why?
