Adding a NVMe drive as a L2ARC cache drive?
In another thread, I mentioned upgrading my TrueNAS Scale system 25.04.1 to a newer motherboard and faster processor (an i7-14700k) processor. The motherboard comes with three NVMe slots, of which one is a boot drive.
When I look at the current memory usage, I see the following:
The motherboard is capable of 192GB ECC memory across four slots, but unfortunately 96GB (48GB×2) ECC is extremely expensive compared to 64GB (32GB×2) ECC. I am planning on adding another 64GB by the end of the year.
My VDEV configuration is as follows:
One idea I’m toying with is using one of the NVMe slots for a cheap 500GB drive to use as a L2ARC cache just to say that I’ve done it. One suggestion that I see in other threads is to look at the arc_summary report which shows the following:
ARC status:
        Total memory size:                                      62.6 GiB
        Min target size:                                3.1 %    2.0 GiB
        Max target size:                               98.4 %   61.6 GiB
        Target size (adaptive):                        62.0 %   38.2 GiB
        Current size:                                  62.0 %   38.2 GiB
        Free memory size:                                        9.6 GiB
        Available memory size:                                   7.4 GiB
ARC structural breakdown (current size):                        38.2 GiB
        Compressed size:                               88.6 %   33.8 GiB
        Overhead size:                                  6.6 %    2.5 GiB
        Bonus size:                                     0.8 %  323.6 MiB
        Dnode size:                                     2.5 %  990.2 MiB
        Dbuf size:                                      1.0 %  408.3 MiB
        Header size:                                    0.3 %  135.9 MiB
        L2 header size:                                 0.0 %    0 Bytes
        ABD chunk waste size:                           0.1 %   21.9 MiB
ARC types breakdown (compressed + overhead):                    36.3 GiB
        Data size:                                     93.9 %   34.1 GiB
        Metadata size:                                  6.1 %    2.2 GiB
ARC states breakdown (compressed + overhead):                   36.3 GiB
        Anonymous data size:                          < 0.1 %  132.0 KiB
        Anonymous metadata size:                      < 0.1 %    2.1 MiB
        MFU data target:                               12.2 %    4.5 GiB
        MFU data size:                                 13.1 %    4.8 GiB
        MFU evictable data size:                       10.8 %    3.9 GiB
        MFU ghost data size:                                    10.8 GiB
        MFU metadata target:                           10.2 %    3.7 GiB
        MFU metadata size:                              4.3 %    1.6 GiB
        MFU evictable metadata size:                    0.6 %  216.1 MiB
        MFU ghost metadata size:                                 0 Bytes
        MRU data target:                               67.3 %   24.5 GiB
        MRU data size:                                 80.8 %   29.4 GiB
        MRU evictable data size:                       78.6 %   28.6 GiB
        MRU ghost data size:                                     3.5 GiB
        MRU metadata target:                           10.2 %    3.7 GiB
        MRU metadata size:                              1.8 %  655.4 MiB
        MRU evictable metadata size:                    0.5 %  173.3 MiB
        MRU ghost metadata size:                                 0 Bytes
        Uncached data size:                             0.0 %    0 Bytes
        Uncached metadata size:                         0.0 %    0 Bytes
ARC hash breakdown:
        Elements:                                                 580.0k
        Collisions:                                                 1.7M
        Chain max:                                                     4
        Chains:                                                    19.1k
ARC misc:
        Memory throttles:                                              0
        Memory direct reclaims:                                    71199
        Memory indirect reclaims:                                1841239
        Deleted:                                                   13.0M
        Mutex misses:                                                391
        Eviction skips:                                             8.1k
        Eviction skips due to L2 writes:                               0
        L2 cached evictions:                                     0 Bytes
        L2 eligible evictions:                                   1.6 TiB
        L2 eligible MFU evictions:                      5.2 %   84.1 GiB
        L2 eligible MRU evictions:                     94.8 %    1.5 TiB
        L2 ineligible evictions:                                 6.2 GiB
ARC total accesses:                                               581.9M
        Total hits:                                    99.2 %     577.4M
        Total I/O hits:                               < 0.1 %     123.4k
        Total misses:                                   0.8 %       4.4M
ARC demand data accesses:                              43.6 %     253.6M
        Demand data hits:                              99.9 %     253.3M
        Demand data I/O hits:                         < 0.1 %      39.7k
        Demand data misses:                             0.1 %     243.3k
ARC demand metadata accesses:                          55.6 %     323.3M
        Demand metadata hits:                         100.0 %     323.2M
        Demand metadata I/O hits:                     < 0.1 %      17.0k
        Demand metadata misses:                       < 0.1 %     104.0k
ARC prefetch data accesses:                             0.8 %       4.9M
        Prefetch data hits:                            17.5 %     853.7k
        Prefetch data I/O hits:                         0.1 %       6.8k
        Prefetch data misses:                          82.4 %       4.0M
ARC prefetch metadata accesses:                       < 0.1 %     244.8k
        Prefetch metadata hits:                        42.0 %     102.8k
        Prefetch metadata I/O hits:                    24.5 %      59.9k
        Prefetch metadata misses:                      33.6 %      82.1k
ARC predictive prefetches:                             99.7 %       5.1M
        Demand hits after predictive:                  93.2 %       4.8M
        Demand I/O hits after predictive:               0.9 %      46.2k
        Never demanded after predictive:                5.9 %     302.7k
ARC prescient prefetches:                               0.3 %      15.2k
        Demand hits after prescient:                   97.6 %      14.8k
        Demand I/O hits after prescient:                1.7 %        264
        Never demanded after prescient:                 0.7 %        102
ARC states hits of all accesses:
        Most frequently used (MFU):                    95.6 %     556.3M
        Most recently used (MRU):                       3.6 %      21.1M
        Most frequently used (MFU) ghost:             < 0.1 %      26.4k
        Most recently used (MRU) ghost:               < 0.1 %     100.7k
        Uncached:                                       0.0 %          0
DMU predictive prefetcher calls:                                  124.8M
        Stream hits:                                   33.0 %      41.2M
        Hits ahead of stream:                           7.8 %       9.7M
        Hits behind stream:                            29.9 %      37.4M
        Stream misses:                                 29.3 %      36.6M
        Streams limit reached:                         46.6 %      17.1M
        Stream strides:                                           809.6k
        Prefetches issued                                           4.3M
If I’m reading this correctly, then I probably won’t benefit from adding a NVMe drive as a Cache VDEV. But, if I did that, I would just install the drive and assigning it to Cache VDEV. Is that correct?
If you do not need a cache drive (and I would say definitely not), then why in the world would you want to add it? Memory is faster than your nvme, so you have planety right now and you might add more so do not add it.
You’re reading correctly: You cannot improve near perfection, and any L2ARC device would remain… essentially unused.
By the same token, you may cancel this RAM upgrade and reallocate the budget to something else. “ZFS loves RAM” but you’ve fed your system so well that more RAM isn’t likely to be useful.
The RAM upgrade will still probably take place just because the price is right and I may want to try out some virtual machines on TrueNAS as well as ProxMox. From my perspective, it’s a home lab.
