After updating immich, it wont start anymore
lifecycle.log says :
[2025/04/29 18:43:05] (ERROR) app_lifecycle.compose_action():56 - Failed ‘up’ action for ‘immich’ app: machine-learning Pulling \n server Pulling \n machine-learning Error Get “https://ghcr.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)\n server Error context canceled\nError response from daemon: Get “https://ghcr.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)\n
Cant roll back either, app needs to be running to be able to roll back :confused:
Can you get it to launch if you go to the Edit screen and uncheck Enable Machine Learning? Doesn’t solve the problem (unless you don’t need machine learning enabled), but it could get it running so you can roll back for now.
Im afraid to do any changes … I do reach https://ghcr.io/v2 from the shell, so its not connectivity issue.
Well ok, it started now … Didnt do anything, maybe it was just a some sort of hickup.
