Am I cooked? Resilvering 10tb is taking 5 months
There are several thousand files on here. I’m a photographer and it’s how I hang on to old projects I was contracted for.
OH MY GOD THERES ACTUALLY NO WAY DUDE
thanks lol
for some reason, it just needed a restart. I had seen several people in threads concerned about losing data over a restart now, but thats all it took
They thought I was joking about this.
Just curious, what’s the time estimate now?
No swap in Fangtooth… :roll_eyes:
Initiating resilver involves collecting metadata, and should be bound by IOPS rather than CPU.
But if restarting fixed it I have nothing more to say. :open_mouth: (see above link)
I think he meant hot swap of the hard drives as the physical feature
Fair enough, but neither the motherboard nor the system appear to support hot swap (and even with a hot swap-capable backplane, it would still be recommended to power off to change drives).
7hrs 30mins
…I’m uhh, wondering if maybe that was the root cause in that case
OP never mentioned hot swapping anything.
Oh you’re right, I mixed up users. Both had yellow for their profile picture!! :frowning:
I’m pretty sure TrueNAS supports hot-swap of drives (but not M.2, because they aren’t spec’d as hot swappable). However, most consumer grade motherboard’s I’ve seen have hot-swap capability, but it’s not turned on by default. @novaseline if you’re comfortable poking around in your BIOS, have a look and see if that’s a setting you can enable.
Regardless of whether or not this was the cause of the issue, something just seemed super off. This is a well spec’d system, lots of RAM and CPU power. It should have been going as fast as the new drive could handle it. Glad it was ultimately “nothing.”
