Hardware
Framework Desktop
AMD Ryzen AI Max
Integrated Radeon 8060S
Problem
VAAPI hardware acceleration fails in a Jellyfin Docker container on TrueNAS SCALE. The container has access to both /dev/dri and /dev/kfd, but FFmpeg fails to initialize VAAPI on the AMD GPU.
I first ran the stock TrueNAS Jellyfin app with non-NVIDIA GPU passthrough and the container exposed /dev/dri, but not /dev/kfd. So, I moved Jellyfin to a custom Docker container and mapped both /dev/dri and /dev/kfd.
Inside the container I made sure
/dev/dri/renderD128 exists
/dev/kfd exists
FFmpeg lists VAAPI support
FFmpeg lists VAAPI encoders
Reproduction command:
/usr/lib/jellyfin-ffmpeg/ffmpeg -hide_banner -loglevel verbose -vaapi_device /dev/dri/renderD128 -f lavfi -i testsrc2=size=1280x720:rate=30 -t 5 -vf ‘format=nv12,hwupload’ -c:v h264_vaapi -f null -
Result
libva loads radeonsi_drv_video.so, then fails with
_amdgpu_device_initialize: amdgpu_query_gpu_info_init failed
amdgpu: amdgpu_device_initialize failed
Failed to initialise VAAPI connection: 2
Additional notes
The same failure occurs when running the command as root inside the container
sudo dmesg | grep -Ei ‘amdgpu|drm|kfd|firmware’ shows no obvious amdgpu or firmware errors
This appears to be a compatibility issue between TrueNAS SCALE and the Radeon 8060S graphics stack on this hardware, not a simple container permissions problem
If anyone has any suggestions on how I could get around this, please let me know. Otherwise, when 26.04 comes out (hopefully next month) it would be great to add support for AMD Radeon 8060S on Framework Desktop systems, specifically VAAPI initialization for container workloads such as Jellyfin.
