On TrueNAS Scale 24.10.1, I updated to the most recent version of the Jellyfin container, going from 1.1.14 to 1.1.16. After the update, My GPU was no longer recognized for transcoding, and the playback would fail.
I went to edit the container configuration, and made sure “Use this gpu” was checked. After checking that box, I would expect the container to start as normal, but instead TrueNAS came up with an error indicating that the container could not start, and pointed to /var/log/app_lifecycle.log for more information.
I updated TrueNAS to 24.10.2 in hopes that it would fix the issue (as I know the release had Nvidia fixes), but there was no difference. Below is the output in /var/log/app_lifecycle.log:
[2025/01/29 12:03:48] (ERROR) app_lifecycle.compose_action():56 - Failed 'up' action for 'jellyfin' app: Network ix-jellyfin_default Creating
Network ix-jellyfin_default Created
Container ix-jellyfin-jellyfin-1 Creating
Container ix-jellyfin-jellyfin-1 Created
Container ix-jellyfin-jellyfin-1 Starting
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy'
nvidia-container-cli: device error: GPU-de46ebef-5d4b-b3c4-dc71-e559845dafd7: unknown device: unknown
After this, I rolled back Jellyfin to the previous version (1.1.14), and the issue persists. I can get the container to start by removing the “Use this GPU” toggle, but I cannot start the container with the GPU.
