Hello, today I logged in my truenas scale but under ‘apps’ there aren’t any apps installed. if I browse catalog I can see that the apps already installed are available to install. But these app are running. The only problem is that they not showed up. How can I solve ?
Thanks in advance
Alex
I had this problem with Dragonfish yesterday after a UPS-initiated shutdown and reboot. Another reboot fixed it.
Unfortunately It didn’t work. I tryed several times
Did you verify the apps screen is point at the right pool? (Configuration->Choose Pool)
Yes it is. Everythink seems ok. Apps working as never occurred, but the apps are not showed. The problem will be when I will have to update them if I don’find the issue
Is it the same in all browsers?
I have the same problem.
App is running, I can reach it on the ip:port.
I can also see the metadata.yaml file under /mnt/.ix-apps/app_configs/scrutiny/
I tried reboot of TrueNAS, browser refresh, cach clear and other browser.
Got it, there was a metadata.yaml.save file in that directory, after deleting the file the app showed up.
