Automatically unlock encrypted dataset on USB drive on reboot?
I have two USB drives connected to my TrueNAS Mini X+, for onsite and offsite backup. Because the offsite one is, well, offsite, I want to keep it encrypted. For uniformity’s sake, I am encrypting the onsite drive as well.
Because the main dataset is not encrypted, I cannot back them up to an already encrypted pool. My layout for the drives, and the backup datasets, is this:
Is there a way to automatically unlock the datasets named “backup” when the drives are mounted, or when the TrueNAS reboots and they are already attached?
With TrueNAS, only if the User Key format is a keystring, not passphrase.
If you want it to work with a passphrase, you’d need to use a custom script, which would need to know your passphrase.
