I’m looking for some advice on building a NAS (PC). I’m considering upgrading my CPU and motherboard. Currently, I have an i7-3770K with an ASUS P8H61 motherboard. However, I believe the onboard graphics are no longer working.
- You should try to just buy a new (used) CPU. The “k” one is absolutely unncessary for such use case, so I recommmend to buy a normal i7 3770 (without th “K”)
or, if you want to save some power, try to find the low power variants (Its the “T” tag.) On eBay these are for literally pennies.
“I’ve been looking at an i5-12600KF and an Asus Prime B760-PLUS. Would this be a good choice for my needs? I plan to use the NAS for data backup, transfers, virtual machines, etc. (I’m also open to AMD alternatives if they would be a better fit.)”
How many VM-s are thinking of?
Your motherboard only has 2 RAM slots and only supports 16GB RAM maximum.
I would say, that these capabilities are only allow you to run multiple targeted VMs ( Like a Pihole, firewall, home assistant, etc) and Maybe one Linux VM with max 4 GB RAM assigned.
Everything more than that would make your life harder.
(Honestly, with this config I would not bother with any VMs… Tha Hypervisor of TrueNAS Scale v23 was really broken (they might have fixed it by the v24 release, I did not try this, so if anybody can confirm that happened, would be nice) and to use it was really painful. (I am in the process of moving my TrueNAS from bare metal to under Proxmox, because of this. )
I dont recommend to buy the K or KF CPUs. YOu dont need the tuning possibilities for this application, and having that on-CPU GPU is a really big help for troubleshooting yout system.
If you want to run multiple VMs, I would rather go for more CPU cores than the tuning capability. (so, like the i7 12700 (non k) )
Spare Equipment I Have:
(unfortunately, you did not detail, what your current config is.)
Power Supply:TX650
It is always useful to use bigger PSU.
RAM: 16GB DDR3 (I don’t think this will work with the Asus P8H61, though.)
(It SHOULD work, since that MoBo is DDR3 capable, but you only have 2 slots that means, it only makes sense, if there is currently only 8 (2x4) GB RAM is in the PC. If it has already 2x8GB, you will not benefit anything from it.)
Storage: 2 SSDs, 2 HDDs
It they are the same size SSD-s and HDD-s then you can use them as mirrored devices. (they not necesssarily have to be the same manufacturer)
If they are different size, you will only be able to use both with the smaller size)
Network:2 × 10GbE NICs
That is nice, however, I am not sure, your current config will be able to provide that speed on the HDD speed side.
But I guess, the speed will be higher than Gbit for sure.
GPU: RX580
As others also stated, I dont really see any points to use it.
AMD PRISM COOLER
I’m considering connecting my GPU, NICs, and eventually a SATA expansion card. Would this setup be viable?
The setup would be, but your current MoBo does not have the necessary number of PCIe slots for that.
You didnot detail, which version of the P8H61 you have. (Number of PCI/PCIe slot)
So, my conclusion is that this config is OK to use as only a NAS (Maybe some really light VM loads.)
But I would only use it for purely TrueNAS only.
If you decide to replace the MoBo and CPU, you should take one with 4 Memory slots, to be able to support al least 64GB support (it will allow you to upgrade later) and athe most possible number of at least PCIe4x slots. (if you want to use all those additional cards.)
I would go after the most available sATA ports on the MoBo (gamer MoBos, however more expensive, have usually 6+sATA ports), rather then using add-on sATA cards.
Also I dont recommend sATA cards, but HBA-s instead. (they have to be flashed to IT mode though…)
Thanks in advance for your advice!
[/quote]
