Cannot connect to TrueNAS host from within LXC Instance
TrueNAS Scale 25.04, LXC Debian Bookworm, NIC: eth0 (MACVLAN)
I recently migrated from Core to Scale. In Core, I was running a Roon server within a Debian VM. This time I decided to go lightweight with the new Incus LXC containers. The server is up and running, and clients recognize it; however, when I go to attach an smb share on the same TrueNAS host, it’s unsuccessful.
I proceed to troubleshoot various network connection attempts. I initiate a shell into the container and attempt an ssh into the TrueNAS host. I can ssh into the TrueNAS host from other computers on my network; however, from within the container I get ssh: connect to host <host ip> port 22: No route to host. What’s strange is that I can ssh into other computers on my network from within the container.
Does anyone have any ideas as to what’s going on? Any insight would be much appreciated.
Never used macvlan myself, so can’t help you with the exact networking question. However, you can mount a host directory into an LXC container. Moreover, you can mount it as read-only. Perhaps this can solve your issue.
@swc-phil, thanks for the reply. I tried the “add disk” route for other datasets to which I needed write access. I’m still trying to get that to work. The Roon server connects specifically through smb shares, however.
Never used Roon. However, a quick googling showed that it can work with local directories.
Never used Incus either, but I’m 99% sure it’s capable of bind mounts. I think that more seasoned incus users could help you.
In Truenas Scale 24.04 (and 24.10) if apps had to connect with host I had to do a Bridge connection. I have to create a bridge (br0) and add the nic (eno1) to the bridge and then all apps can connect. I dont know if 25.04 will be the same.
It’s a macvlan limitation. You cannot contact the host.
With LXC containers there is also generally a limitation to mounting SMB or NFS shares, due to the container being unprivileged. For example in Proxmox, you must mount the SMB share on the host files system then bind mount it into the LXC container. The alternative is use a privileged container, which a security risk.
I like the suggestion to just bind mount the dataset your library sits on if you want to go LXC
Exactly. You need to use a bridge instead of a MACVLAN to communicate with the host.
Thanks for the info. That seems promising. I assume that once you have the NIC setup on the bridge, the lxc instance then has its own MAC address that’s broadcast to the local network. Is that true? Would you be able to point me to some documentation on how to do this?
Thanks for the reply. You’re correct. I had forgotten and misspoke. I tried the add “disks” approach, and permissions seemed to be a nightmare. I need Roon to not only be able to read the media but to write as well as the host “disks” are where I store the Roon index backups.
Thanks for the reply and info. Emo’s approach appears promising.
Thanks for the reply. What do you think about the approach above suggested by @Emo? Would that work in an unprivileged container?
I just brought read-only mode as a plus. It’s not necessary.
The issue seems to be when I add as a “disk” a dataset that’s configured as an smb share. I can’t get permissions to work for the life of me. I add the group “apps” to the ACL with modify permissions, and I still can’t write to the “disk” from within the lxc. I’ve also tried just adding the user “apps” to the ACL.
Seems like the issue can be solved with LXC user/group id mapping. But I don’t have experience with it.
It seems that I’m going to encounter the same issues going back to running the Roon server in a VM. It appears that the only options for networking for the VMs are also just Bridge and MACVLAN. I’m confused as to why networking worked so smoothly on VMs in Core.
Well, I have now determined that I definitely want to go the share route rather than adding a dataset as a “disk.” The latter just isn’t as flexible. Adding to an LXC instance a “disk” which has already been added as a “disk” to another LXC instance is not allowed.
How were you able to achieve this? I’ve got the LXC instance setup with a Bridge, and then within the LXC, I add an eno1 configuration to /etc/network/interfaces, followed by “ifup eno1.” I get: Cannot find device “eno1”.
In 25.04 after adding bridge (br0) to a LXC instance the nic is called eth0.
Have you just added apps to the ACL or are you actually using the mapped container user to actually perform the actions? Just having the ID mapping for apps and permissions on the dataset doesn’t automatically grant any other user permissions.
This will be allowed in 25.04.1: Jira.
