Since I can’t get Flaresolverr or Byparr to work, I’m trying to install Bitmagnet, since I’m given to understand it can connect to Sonarr and make it work for protected indexers.
Has anyone gotten this to work? I keep getting a bunch of errors in the Bitmagnet log about it having trouble connecting to the Postgres container. It’s just this giant block over and over:
2025-07-17 00:27:47.264598+00:00e[33mWARNe[0m tmdb/requester_lazy.go:40 you are using the default TMDB api key; TMDB requests will be limited to 1 per second; to remove this warning please configure a personal TMDB api key
2025-07-17 00:27:48.266250+00:00e[33mWARNe[0m postgres/postgres.go:92 failed to ping database, retrying... {"error": "failed to connect to `user=postgres database=bitmagnet`:\n\t127.0.0.1:5432 (localhost): dial error: dial tcp 127.0.0.1:5432: connect: connection refused\n\t[::1]:5432 (localhost): dial error: dial tcp [::1]:5432: connect: connection refused\n\t127.0.0.1:5432 (localhost): dial error: dial tcp 127.0.0.1:5432: connect: connection refused\n\t[::1]:5432 (localhost): dial error: dial tcp [::1]:5432: connect: connection refused"}
//above log repeats 9 more times with new timestamps
2025-07-17 00:27:57.292100+00:00e[31mERRORe[0m worker/worker.go:196 error starting worker {"key": "http_server", "error": "timed out waiting for ping: failed to connect to `user=postgres database=bitmagnet`:\n\t127.0.0.1:5432 (localhost): dial error: dial tcp 127.0.0.1:5432: connect: connection refused\n\t[::1]:5432 (localhost): dial error: dial tcp [::1]:5432: connect: connection refused\n\t127.0.0.1:5432 (localhost): dial error: dial tcp 127.0.0.1:5432: connect: connection refused\n\t[::1]:5432 (localhost): dial error: dial tcp [::1]:5432: connect: connection refused"}
2025-07-17 00:27:57.292309+00:00github.com/bitmagnet-io/bitmagnet/internal/boilerplate/worker.(*registry).Start
2025-07-17 00:27:57.292350+00:00/src/internal/boilerplate/worker/worker.go:196
2025-07-17 00:27:57.292379+00:00github.com/bitmagnet-io/bitmagnet/internal/boilerplate/app/cmd/worker.New.func1
2025-07-17 00:27:57.292435+00:00/src/internal/boilerplate/app/cmd/worker/command.go:42
2025-07-17 00:27:57.292464+00:00github.com/urfave/cli/v2.(*Command).Run
2025-07-17 00:27:57.292488+00:00/go/pkg/mod/github.com/urfave/cli/v2@v2.27.5/command.go:276
2025-07-17 00:27:57.292510+00:00github.com/urfave/cli/v2.(*Command).Run
2025-07-17 00:27:57.292562+00:00/go/pkg/mod/github.com/urfave/cli/v2@v2.27.5/command.go:269
2025-07-17 00:27:57.292587+00:00github.com/urfave/cli/v2.(*Command).Run
2025-07-17 00:27:57.292610+00:00/go/pkg/mod/github.com/urfave/cli/v2@v2.27.5/command.go:269
2025-07-17 00:27:57.292632+00:00github.com/urfave/cli/v2.(*App).RunContext
2025-07-17 00:27:57.292672+00:00/go/pkg/mod/github.com/urfave/cli/v2@v2.27.5/app.go:333
2025-07-17 00:27:57.292696+00:00github.com/bitmagnet-io/bitmagnet/internal/boilerplate/cli.New.func4.1
2025-07-17 00:27:57.292718+00:00/src/internal/boilerplate/cli/cli.go:58
2025-07-17 00:27:57.294381+00:00panic: timed out waiting for ping: failed to connect to `user=postgres database=bitmagnet`:
2025-07-17 00:27:57.294579+00:00127.0.0.1:5432 (localhost): dial error: dial tcp 127.0.0.1:5432: connect: connection refused
2025-07-17 00:27:57.294609+00:00[::1]:5432 (localhost): dial error: dial tcp [::1]:5432: connect: connection refused
2025-07-17 00:27:57.294632+00:00127.0.0.1:5432 (localhost): dial error: dial tcp 127.0.0.1:5432: connect: connection refused
2025-07-17 00:27:57.294670+00:00[::1]:5432 (localhost): dial error: dial tcp [::1]:5432: connect: connection refused
2025-07-17 00:27:57.294690+00:002025-07-17T00:27:57.294690180Z
2025-07-17 00:27:57.294709+00:00goroutine 50 [running]:
2025-07-17 00:27:57.294728+00:00github.com/bitmagnet-io/bitmagnet/internal/boilerplate/cli.New.func4.1()
2025-07-17 00:27:57.294760+00:00/src/internal/boilerplate/cli/cli.go:59 +0xde
2025-07-17 00:27:57.294778+00:00created by github.com/bitmagnet-io/bitmagnet/internal/boilerplate/cli.New.func4 in goroutine 49
2025-07-17 00:27:57.294800+00:00/src/internal/boilerplate/cli/cli.go:52 +0xc5
Here’s my docker compose file. Sorry this is turning into a wall of text, haha.
networks:
bitmagnet:
driver: bridge
ipam:
- gateway: 192.168.56.1
subnet: 192.168.56.0/24
driver: default
services:
bitmagnet:
command:
- worker
- run
- '--all'
container_name: bitmagnet
depends_on:
gluetun:
condition: service_healthy
postgres:
environment:
- PUID=568
- GUID=568
image: ghcr.io/bitmagnet-io/bitmagnet:latest
network_mode: service:gluetun
restart: unless-stopped
volumes:
- /mnt/Main/configs/custom/bitmagnet/appdata:/root/.config/bitmagnet
gluetun:
cap_add:
- NET_ADMIN
container_name: bitmagnet-gluetun
devices:
- /dev/net/tun:/dev/net/tun
environment:
[redacted]
extra_hosts:
- postgres:192.168.56.11
image: qmcgaw/gluetun:latest
networks:
bitmagnet:
ipv4_address: 192.168.56.10
ports:
- '3333:3333'
- 3334:3334/tcp
- 3334:3334/udp
restart: always
postgres:
container_name: bitmagnet-postgres
environment:
- POSTGRES_PASSWORD=postgres
- POSTGRES_DB=bitmagnet
- PGUSER=postgres
- PUID=568
- GUID=568
healthcheck:
interval: 10s
start_period: 20s
test:
- CMD-SHELL
- pg_isready
image: postgres:16-alpine
networks:
bitmagnet:
ipv4_address: 192.168.56.11
ports:
- '5432:5432'
shm_size: 1g
volumes:
- /mnt/Main/configs/custom/bitmagnet/pgdata:/var/lib/postgresql/data
The IP addresses were changed from 192.168.55.x to 192.168.56.x to avoid conflicting with my qBittorrent’s Gluetun container. Here’s the version on GitHub, for reference.
