Cloudflare DDNS Setup on SCALE 24.10.2
I am following a guide on how to set up nextcloud on my TrueNAS SCALE system. The step I am on right now requires me to have set up the DNS records of my domain to point to my server, and since I don’t have a permanent public IP, I need to set up a Dynamic DNS method.
From what I have been able to understand, Cloudflare doesn’t really have support for DDNS, instead offering some hacky workarounds such as third-party clients or creating a script to make calls to their API to edit the domain’s DNS records on every call.
I cannot change my domain from Cloudflare to a different service, as my domain initially had its DNS handled by Namecheap (also the registrar I have bought the domain from.) I had to switch from Namecheap to Cloudflare because I need a valid SSL certificate for my domain, and Cloudflare makes that much simpler by just issuing an automatic one when a domain is on their DNS.
Apparently, there was an app in the Truecharts catalog called cloudflare-ddns that served this exact purpose. But obviously, with 20.10 Truecharts is basically gone and I cannot use that Kubernetes-based application anymore.
I’ve also tried using ddns-updater which is on the official TrueNAS app catalog but with no luck. As soon as I finish entering all the parameters and press install, the status shows ‘deploying’ for a couple of seconds and immediately stops. There is no real error message printed to the system console, either.
I enter my ddns-updater parameters like this:
Provider -         Cloudflare
Domain -           nextcloud.mydomain.tld (there is no type A+ DDNS record in my records as Cloudflare does not support that)
Host -             EMPTY
IP Version -       IPv4 and IPv6
Zone ID -          [the zone ID in my domain overview]
TTL -              1
Proxied -          Enabled
Token -            EMPTY (not sure what to put here)
User Service Key - [the account ID in my domain overview]
Email -            [the email of my Cloudflare account]
API Key -          [an API key I generate for my account for the Edit Zone DNS function for my domain. verified working with curl]
Am I doing something wrong? I suspect that I am.
How should I go about setting up DDNS on my Cloudflare domain and making it point to my server? Should I use ddns-updater with a different configuration of parameters? Should I set up some sort of script on my server how Cloudflare wants it? (I’m not sure how to do that)
I am a noob when it comes to TrueNAS and I am now realizing that this project is a bit beyond my depth for a first endeavor. I’m intending to struggle through it, though.
Any help on this is greatly appreciated:) Thanks!
you can run a cloudflare ddns upate in as a custom app using this yaml.
version: '3.5'
services:
  cloudflare-ddns:
    image: oznu/cloudflare-ddns:latest
    restart: always
    environment:
      - API_KEY=
      - ZONE=yourdomain.com
      - ZONE_ID=
      - PROXIED=false
this works perfectly fine for me, too. But is there a possibility to add an additional subdomain that is showing to the same ip? or is there another solution for the following case:
my nextcloud has the domain: domain.org
collabora has the subdomain: collabora.domain.org
but in the end both should point to the same ip.
To do that, you should use a CNAME. In the DNS settings for your site on cloudlfare, add a new record, choosing CNAME as the type. In your example, you’d set the Name as “collabora” and the Target as “domain.org.”
Thank you my beautiful shining star. OP had my exact same situation and this worked perfectly
