Hi Everyone, I am having an issue trying to integrate Collabora with Nextcloud hoping to get some help. I went through the references below, along with other guides, but Collabora seem to still have issue connecting with Nextcloud. Any help would be appreciated.
Information:
- TrueNAS Community: 25.04
- Nextcloud App Version: 31.0.4
- Nextcloud Version: 1.6.22
- Collabora App Version: 25.04.1.1.1
- Collabora Version: 1.2.25
- Nginx Proxy Manager Version: 2.12.3
I followed the A full guide for installing Nextcloud on TrueNAS Scale with Collabora integration and outside access through Nginx Proxy Manager pretty much exactly with a few tweaks.
One other note is I also have OnlyOffice integrated with the same approach, but that seem to work fine. But not sure if both OnlyOffice and Collabora can exist in the same time? OnlyOffice is not using WebSocket on Nginx Proxy Manager.
Nextcloud Configuration:
- Most configurations are default.
- Host:
nextcloud.domain.tld - WebUI Port:
30027(default) - Certificate ID:
nextcloud Certificate- This is a self-signed certificate created in TrueNAS for Nextcloud
- This is created using EC instead of RSA (not sure if that matters)
Collabora Configuration:
- Server Name:
collabora.domain.tld:443 - WebUI Port:
9980(default) - Certificate ID:
collabora Certificate- This is a self-signed certificate created in TrueNAS for Collabora
Nginx Proxy Manager Nextcloud:
- Domain Names:
nextcloud.domain.tld - Scheme:
https - Forward Hostname / IP:
10.0.0.201(TrueNAS IP) - Forward Port:
30027 - Cache Assets:
off - Websocket Support:
off - Block Common Exploits:
on - SSL Certificate:
nextcloud.domain.tld(Cloudflare Let’s Encrypt) - Force SSL:
on - HSTS Enabled:
on - HTTP/2 Support:
off - HSTS Subdomains:
off
Nginx Proxy Manager Collabora:
- Domain Names:
collabora.domain.tld - Scheme:
9980 - Cache Assets:
on - Block Common Exploits:
collabora.domain.tld(Cloudflare Let’s Encrypt) - Force SSL:
on - HSTS Enabled:
off
So with the above configuration, Nextcloud Office indicated that Collabora Online server is reachable.
Collabora Online Development Edition 25.04.1.1 f22c9fed45
URL used by the browser: https://collabora.domain.tld:443
Nextcloud URL used by Collabora: https://nextcloud.domain.tld (Determined from the browser URL)
But when I try to create a new document, I get the following error.
Document loading failed
Failed to establish socket connection or socket connection closed unexpectedly. The reverse proxy might be misconfigured, please contact the administrator. For more info on proxy configuration please checkout https://sdk.collaboraonline.com/docs/installation/Proxy_settings.html
The collabora log gave this error
2025-05-03 18:25:41.086244+00:00wsd-00001-00020 2025-05-03 11:25:41.086187 -0700 [ websrv_poll ] ERR #31: Rejecting WebSocket upgrade with: origin [https://collabora.domain.tld] expected [https://collabora.domain.tld:443] instead| net/WebSocketHandler.hpp:1033
One thing I tried was setting the Collabora Server Name to 10.0.0.201 (TrueNAS IP). Nextcloud also shows Collabora Online server is reachable. But I am experiencing two different scenarios.
- If I access the Collabora Web UI at
https://10.0.0.201:9980/browser/dist/admin/admin.htmlfirst, and login, then Nextcloud will load the document successfully. - But if I go to a different computer, or even a private session where I have not logged into the Collabora Web UI, I am getting an error of
Document loading failed, Failed to load Nextcloud Office - please try again later. I was monitoring the Collabora logs, but it did not output anything new. Nextcloud logs (below) did not seem to give any error? (The10.0.0.101is Nginx Proxy Manager IP).
2025-05-03 18:19:37.854393+00:00fdd0:0:0:3::3 (127.0.0.1) - - [03/May/2025:18:19:37 +0000] "GET /status.php HTTP/1.1" 200 1097 "-" "curl/7.88.1"
2025-05-03 18:19:42.817559+00:00172.16.6.3 (10.0.0.101) - - [03/May/2025:18:19:42 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 707 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36"
2025-05-03 18:19:45.814401+00:00fdd0:0:0:3::3 (10.0.0.101) - - [03/May/2025:18:19:45 +0000] "GET /apps/files/api/v1/views HTTP/1.1" 200 759 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0"
2025-05-03 18:19:45.922284+00:00172.16.6.3 (10.0.0.101) - - [03/May/2025:18:19:45 +0000] "PROPFIND /remote.php/dav/files/yk/Alpha.odt HTTP/1.1" 207 1460 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0"
2025-05-03 18:19:45.992023+00:00fdd0:0:0:3::3 (10.0.0.101) - - [03/May/2025:18:19:45 +0000] "GET /apps/files/api/v1/views HTTP/1.1" 200 759 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0"
2025-05-03 18:19:46.021593+00:00172.16.6.3 (10.0.0.101) - - [03/May/2025:18:19:45 +0000] "PROPFIND /remote.php/dav/files/yk//Alpha.odt/ HTTP/1.1" 207 1453 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0"
2025-05-03 18:19:46.028736+00:00fdd0:0:0:3::3 (10.0.0.101) - - [03/May/2025:18:19:45 +0000] "POST /apps/richdocuments/token HTTP/1.1" 200 1025 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0"
2025-05-03 18:19:46.840039+00:00172.16.6.3 (10.0.0.101) - - [03/May/2025:18:19:46 +0000] "GET /index.php/apps/files/preview-service-worker.js HTTP/1.1" 200 6468 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0"
2025-05-03 18:19:47.947510+00:00127.0.0.1 (-) - - [03/May/2025:18:19:47 +0000] "GET /status.php HTTP/1.1" 200 1097 "-" "curl/7.88.1"
2025-05-03 18:19:47.951836+00:00fdd0:0:0:3::3 (127.0.0.1) - - [03/May/2025:18:19:47 +0000] "GET /status.php HTTP/1.1" 200 1097 "-" "curl/7.88.1"
2025-05-03 18:19:57.029057+00:00172.16.6.3 (10.0.0.101) - - [03/May/2025:18:19:56 +0000] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 304 705 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:138.0) Gecko/20100101 Firefox/138.0"
2025-05-03 18:19:58.034660+00:00127.0.0.1 (-) - - [03/May/2025:18:19:58 +0000] "GET /status.php HTTP/1.1" 200 1097 "-" "curl/7.88.1"
Reference
