What I want to do: run LM Studio Bionic with GPU offload on Ubuntu (25.10) running in Truenas (25.10.6) container with Nvidia graphic card (RTX 2000 ADA). Currently LM Studio Bionic does not see any GPU.
I got nvidia drivers installed in Apps->Settings, on Truenas host, nvidia-smi is able to see my card.
In the Ubuntu, when I try do install drivers, I got following errors:
Setting up linux-modules-nvidia-595-server-6.17.0-41-generic (6.17.0-41.41) ...
linux-image-nvidia-6.17.0-41-generic: constructing .ko files
/usr/bin/ld.bfd: cannot open linker script file /usr/src/linux-headers-6.17.0-41-generic/scripts/module.lds: No such file or directory
sha256sum: nvidia-drm.ko: No such file or directory
nvidia-drm.ko: FAILED open or read
sha256sum: nvidia-modeset.ko: No such file or directory
nvidia-modeset.ko: FAILED open or read
sha256sum: nvidia-peermem.ko: No such file or directory
nvidia-peermem.ko: FAILED open or read
sha256sum: nvidia-uvm.ko: No such file or directory
nvidia-uvm.ko: FAILED open or read
sha256sum: nvidia.ko: No such file or directory
nvidia.ko: FAILED open or read
sha256sum: WARNING: 5 listed files could not be read
dpkg: error processing package linux-modules-nvidia-595-server-6.17.0-41-generic (--configure):
installed linux-modules-nvidia-595-server-6.17.0-41-generic package post-installation script subprocess returned error exit status 1
dmesg: read kernel buffer failed: Operation not permitted
dpkg: dependency problems prevent configuration of linux-modules-nvidia-595-server-generic:
linux-modules-nvidia-595-server-generic depends on linux-modules-nvidia-595-server-6.17.0-41-generic (= 6.17.0-41.41); however:
Package linux-modules-nvidia-595-server-6.17.0-41-generic is not configured yet.
dpkg: error processing package linux-modules-nvidia-595-server-generic (--configure):
dependency problems - leaving unconfigured
aaand nvidia-smi in container says:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
What am I doing wrong?
