Create virtualdisk
Trying to setup a new veaem hardened repo, they require two virtual disks of ~100gb each. I know how to configure the VM on setup to add one virtual HDD but how do i add a virtual HDD after the VM’s already setup initially?
I created the second ZFS pool and dataset, but when trying to add device → Disk → zvol only shows my first disk and only allows me to set sector size and not disk size or anythign else
Guide above doesn’t show how to do it either, only way I can think is by janking it by going through the steps to create a second VM, creating the new disk within that widnow but not completing the setup. And then applying the second disk created frolm that process to the first vm. Seems so counterintuitive.
You have to create a second zvol.
Then you attach that as a disk to the VM.
