Dashboard Storage Widgets Incorrect
Running 24.04.2. Had to replace a failed SSD in a 4 SSD pool. All went fine, everything is working correctly. However, both storage widgets on main dashboard still show degraded. If I go to the Storage item on the left hand menu, all the items are correct. Rebooting didn’t solve the issue. Scrubing the pool didn’t help. How do I correct the info in these two widgets?
Suggest you describe pool layout and provide screenshots.
Browser cache can often cause these issues…
Yes, I cleared the browser cache and now all is well. Thanks for the help.
