Data migration with hard links
I am migrating data from one pool to another.
I have some data hard linked like this:
Dataset
  • Movies
    • Movie folder
      • Movie file.mkv
  • Downloads
    • Movie file.mkv
The two files are hard linked to save space.
How can I move those two folders while preserving the hard links between them? Thanks in advance
Both ZFS Send / Receive and RSync support copying hard links.
I routinely use the following with RSync to copy directory trees with all features:
rsync -aAHSXxv --stats /SOURCE/ /DESTINATION/
And if this is an incremental copy, then I add the option below to make the destination look like the source:
--delete
Now for ZFS replication, (aka Send & Receive), it’s a bit more complicated as the options vary depending on:
  • Source is the top level Dataset or child Dataset
  • If the destination pool is empty
  • Or you want to install the source Dataset in a destination child Dataset
I use the following to clone an entire pool to a different, empty pool:
export MY_SNAP="`date +%H%M%S`"
zfs snapshot -r ${MY_SRC_POOL}@${MY_SNAP}
zfs send  -Rpv  ${MY_SRC_POOL}@${MY_SNAP} | \
  zfs receive -dFu ${MY_DEST_POOL}
zfs destroy -rv ${MY_SRC_POOL}@${MY_SNAP}
zfs destroy -rv ${MY_DEST_POOL}@${MY_SNAP}
Replace MY_SRC_POOL and MY_DEST_POOL with the pool names.
I’ve been told that one of the send or receive options is redundant. But, I use it in a script that works, so I have little incentive to change the script.
If you want to copy just a child Dataset, (and it’s further children), the options vary and I don’t have experience in doing that.
Thanks I used the rsync and it seems to have worked perfectly.
I had to move the dirs into a new dir first and copy them at once instead of one after the other.
In a previous thread it was mentioned that after raidz expansion I would lose space due to old data using the original parity ratio.
Is there a script or something to rewrite each data so as to recover the lost space?
Thanks
There are multiple scripts floating around the Internet, just search zfs rebalance script.
In one of the previous t3 podcast episodes they said that iX is developing its own solution, I believe called zfs rewrite. But afaik there’s no eta when the feature will land in truenas
