Dataset space estimation does not match up
Hiya!
I am having a bit of a strange isuse regarding space estimation on SCALE (TrueNAS-SCALE-22.12.4.2), setup with 1 x RAIDZ2 | 4 wide | 1.82 TiB.
I have a dataset called versioned, on the main pool, with two children, workspace and rsnapshot. The total used for the mother dataset versioned reads 860 GiB on the Datasets tab of the webui. This, however, does not match up with the sum of the workspace and rsnapshot child datasets reported by 64 and 372 GiB respectively, reported in the webui.
I thought this might be the result of me moving a bunch of files, or old snapshots. So, I removed all snapshots and rebooted the NAS, just in case. No changes
Doing du -hs in /mnt/storage/versioned reports 436 GiB correctly, as does /mnt/storage/rsnapshot and /mnt/storage/workspace (64 and 372 GiB respectively).
Am I missing something?
Thank you!
