I’m having an issue with the stack of ddns-updater that is in a constant restart loop. I’m not sure on what exactly it is missing to stay in a running state. I cant attach a log or screen shots of the issue, since I’m a new user. Any help or direction would be appreciated. The app was setup inside of Truenas-scale.
As far as i can tell from the error you wrote it expects a actions.json file to be in a specific folder and either fails because:
a: the file can’t be created because of missing permissions or
b: the file must be created before starting the app and deployment fails because it can’t find the file in the expected folder
yeah the crash loop is almost always the config path, not perms theater.
for the ix ddns-updater app on scale the container wants its config/data dir mounted and an actual config file in there before it stays up. actions.json showing up in the log usually means it never found the real config and fell into a bad entrypoint path.
do this:
stop the app
in the app settings check the host path / storage for config (or create a dataset and point config at it)
drop a minimal config.json in that folder (provider + domain + token, whatever your dns host needs). empty dir = restart loop
start it and watch the app log again
if it still screams about /script/actions.json you are on a weird image tag or a bad custom install. switch back to the catalog default image and recreate the app with only the config host path set.
paste the app storage section + first 30 lines of the log after a clean start if it still loops.
