Default pool expanded on entering datasets
Is there a setting that would define which pool is expanded (to show child datasets) when you enter the Datasets tab in TrueNAS Scale?
For me the backup pool is always expanded and in 99,99 % of cases I don’t need to do anything with it, it’s either the main pool or the apps pool that I need to do something with so I have to close the backup and expand another pool every time. If I delete the pool from url/ui/datasets/pool and have the datasets page reload, the backup pool is always expanded and the name added to the URL.
Rename the backup pool to zBackup.
It’s not named backup but Mirror*. And it’s second in line of pools displayed by the GUI.
You might have to make a feature request.
I think I had made a ticket for it (on Core) where it behaves the same way.
If you ask me, it should remember the state of expanded and collapsed rows.
