I built a NAS using a few disks I had laying around. I’m now hooked and want replace the old disks with 4 new drives.
The main pool I built on the old disks contains some test data and can be deleted except for a dataset ‘ix-applications’ which I believe was created by the system when I installed my 1st app. What happens if I delete the main pool along with this dataset? Will that mess up my installed applications?
The alternative is to do a clean install using the new disks for the main pool.
MikeMen, you started multiple threads lately. You can add your details into your profile signature like a few of the users on the board have and then we just view that.
Stux has a few links and two, expandable lists as an example.
I got my answer to the original question of deleting the main pool with the ix-application dataset.
When I deleted it, TN said it would have to move that and several other system datasets to the remaining pool. It tried to do so, but when it was all over I was left with no applications and no ix-applications dataset.
