Disk SMART eror, pool DEGRADED - what to do?
Hello.
Went into truenas scale the day before yesterday and saw the errors:
Device: /dev/sdd [SAT], not capable of SMART self-check.
2025-02-05 12:30:37
Device: /dev/sdd [SAT], failed to read SMART Attribute Data.
2025-02-05 12:30:37
Device: /dev/sdd [SAT], Read SMART Self-Test Log Failed.
2025-02-05 12:30:37
Device: /dev/sdd [SAT], Read SMART Error Log Failed.
2025-02-05 12:30:38
Pool Main_Pool_1 state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state.
The following devices are not healthy:
* Disk ST18000NM000J-2TV103 ZR51WVQL is FAULTED
2025-02-05 14:16:50
Bl00dWolf-NAS% sudo zpool status -v Main_Pool_1
  pool: Main_Pool_1
 state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
        degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
        repaired.
  scan: scrub repaired 3.25M in 21:39:54 with 0 errors on Thu Feb  6 11:29:43 2025
        NAME                                      STATE     READ WRITE CKSUM
        Main_Pool_1                               DEGRADED     0     0     0
          mirror-0                                DEGRADED     0     0     0
            de06f47c-23a6-493a-b209-ce6b485b758f  FAULTED      3     0     0  too many errors
            1eda4e28-aa78-4e8d-b005-f062186a6991  ONLINE       0     0     0
errors: No known data errors
Bl00dWolf-NAS% sudo smartctl -x /dev/sdd
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.44-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Smartctl open device: /dev/sdd failed: INQUIRY failed
I turned off the power, took out the disk.
I have a SATA → USB orico hub.
Plugged it in, on a normal computer. The disk is visible, it doesn’t make any weird noises, doesn’t think for a long time, etc.
Ran victoria, it can’t read its smart log, but it reads the current smart. No critical errors there.
Ran a quick test on the disk surface, all 18tb passed successfully.
What do you recommend to do?
Should i try to swap two of this disks with each other? To determine maybe there is a cable \ port problem.
It worked ok for about 4 years in this configuration.
I also tried rebooting nas, scrub, zpool clear. Problems occures again =
Thanks in advance.
NAS config
ASROCK J4125-ITX
32GB 2400 DDR4
TrueNAS Scale on Samsung 870 EVO 250GB
Mirror 1 18Tb+18Tb (ST18000NM000J-2TV103)
Mirror 2 22Tb+22Tb (WDC_WUH722222ALE6L4)
Is the drive connected directly to the motherboard when installed in the system? What version of TrueNAS are you running?
i’m not sure actually.
ASROCK J4125-ITX have 4 sata ports.
So SSD 256gb - 1 port (boot dirve), 3 HDD - 3 ports. Aaaaand one HDD via M.2 sata apdater.
But i’m not sure if it is sdd, i’ll try to check it.
Latest.
SCALE ElectricEel-24.10.2
Check it using the drive serial number (ZR51WVQL). The sdd can change on you during reboot.
And another question, were you using a previous version of TrueNAS and if so, what was that version?
One last question, Did you “update the ZFS features” when you shifted to SCALE? This is important as if you did, it limits your ability to roll to the previous version. As a rule of my thumb, Never update the ZFS feature set unless there is a feature you need, or at least wait a few months to ensure your system is completely stable. I never upgrade. No need.
I’m using it almost 5-6 years for now.
Previous before 24.10.2 was 24.10.0.2
Yes.
How can i check it? smartctl not working on it, hdparam too =(
Do you have the ability to change your boot environment back to 24.10.0.2 ?
If you do, try that first. This would just allow you to verify if the drive support changed or a bug was introduced in the newer version. It happens.
Physically look at the drive. Always physically identify a drive if you have problems and/or replacing it. You never want to replace to good drive. In your mirror that would be very bad.
At this time i would also tell you to backup any important information if you can. Better to be safe.
I tried, same.
I know this, I mean how to detect in ssh in linux =)
I don’t have swap drives now, i need to order new one.
Meanwhile can i swap this two drives with each other to see, will ZR51WVQL fail, or other drive? If ZR51WVQL - replace. If now other drive will fail - sata port \ cable problem.
I’ve changed the slot in my nas for ST18000NM000J-2TV103 ZR51WVQL
Now it’s SDE, and i can actually run smartclt on it
Bl00dWolf-NAS% sudo smartctl -x /dev/sde
Device Model:     ST18000NM000J-2TV103
Serial Number:    ZR51WVQL
LU WWN Device Id: 5 000c50 0db51f221
Firmware Version: SC02
User Capacity:    18,000,207,937,536 bytes [18.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database 7.3/5528
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Feb  8 12:13:25 2025 MSK
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, frozen [SEC2]
Write SCT (Get) Feature Control Command failed: scsi error badly formed scsi parameters
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1560) minutes.
Conveyance self-test routine
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   083   064   044    -    221313341
  3 Spin_Up_Time            PO----   091   090   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    125
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   077   060   045    -    47249043
  9 Power_On_Hours          -O--CK   073   073   000    -    24232
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    114
 18 Unknown_Attribute       PO-R--   100   100   050    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   093   000    -    77310722071
190 Airflow_Temperature_Cel -O---K   064   040   000    -    36 (Min/Max 35/36)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    47
193 Load_Cycle_Count        -O--CK   100   100   000    -    1128
194 Temperature_Celsius     -O---K   036   060   000    -    36 (0 24 0 0 0)
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    75
200 Multi_Zone_Error_Rate   PO---K   100   100   001    -    0
240 Head_Flying_Hours       ------   100   253   000    -    23923 (25 52 0)
241 Total_LBAs_Written      ------   100   253   000    -    136404701961
242 Total_LBAs_Read         ------   100   253   000    -    11143013236194
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0a       GPL     R/W      8  Device Statistics Notification
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    768  Current Device Internal Status Data log
0x2f       GPL     R/O      1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS     160  Device vendor specific log
0xa2       GPL     VS   16320  Device vendor specific log
0xa4       GPL,SL  VS     160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xad       GPL     VS      16  Device vendor specific log
0xb1       GPL,SL  VS     160  Device vendor specific log
0xb6       GPL     VS    1920  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc1       GPL,SL  VS       8  Device vendor specific log
0xc3       GPL,SL  VS      24  Device vendor specific log
0xc6       GPL     VS    5184  Device vendor specific log
0xc7       GPL,SL  VS       8  Device vendor specific log
0xc9       GPL,SL  VS       8  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xcd       GPL,SL  VS       1  Device vendor specific log
0xce       GPL     VS       1  Device vendor specific log
0xcf       GPL     VS     512  Device vendor specific log
0xd1       GPL     VS     656  Device vendor specific log
0xd2       GPL     VS   10256  Device vendor specific log
0xd4       GPL     VS    2048  Device vendor specific log
0xda       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%     24149         -
# 2  Short offline       Completed without error       00%     23962         -
# 3  Short offline       Completed without error       00%     23794         -
# 4  Short offline       Completed without error       00%     23626         -
# 5  Short offline       Completed without error       00%     23458         -
# 6  Short offline       Completed without error       00%     23290         -
# 7  Short offline       Completed without error       00%     23122         -
# 8  Short offline       Completed without error       00%     22954         -
# 9  Short offline       Completed without error       00%     22786         -
#10  Short offline       Completed without error       00%     22618         -
#11  Short offline       Completed without error       00%     22450         -
#12  Short offline       Completed without error       00%     22282         -
#13  Short offline       Completed without error       00%     22114         -
#14  Short offline       Completed without error       00%     21957         -
#15  Short offline       Completed without error       00%     21789         -
#16  Short offline       Completed without error       00%     21621         -
#17  Short offline       Completed without error       00%     21453         -
#18  Short offline       Completed without error       00%     21285         -
#19  Short offline       Completed without error       00%     21117         -
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    36 Celsius
Power Cycle Min/Max Temperature:     35/36 Celsius
Lifetime    Min/Max Temperature:     24/60 Celsius
Under/Over Temperature Limit Count:   0/0
SMART Status:                        0xc24f (PASSED)
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         4 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:     10/40 Celsius
Min/Max Temperature Limit:            5/60 Celsius
Temperature History Size (Index):    128 (54)
Index    Estimated Time   Temperature Celsius
  55    2025-02-03 06:43    42  ***********************
 ...    ..(  5 skipped).    ..  ***********************
  61    2025-02-03 12:37    42  ***********************
  62    2025-02-03 13:36    43  ************************
  63    2025-02-03 14:35    42  ***********************
  64    2025-02-03 15:34    42  ***********************
  65    2025-02-03 16:33    43  ************************
  66    2025-02-03 17:32    43  ************************
  67    2025-02-03 18:31    44  *************************
  68    2025-02-03 19:30    44  *************************
  69    2025-02-03 20:29    43  ************************
 ...    ..(  2 skipped).    ..  ************************
  72    2025-02-03 23:26    43  ************************
  73    2025-02-04 00:25    42  ***********************
  74    2025-02-04 01:24    42  ***********************
  75    2025-02-04 02:23    42  ***********************
  76    2025-02-04 03:22    43  ************************
  77    2025-02-04 04:21    42  ***********************
 ...    ..( 11 skipped).    ..  ***********************
  89    2025-02-04 16:09    42  ***********************
  90    2025-02-04 17:08    43  ************************
  91    2025-02-04 18:07    43  ************************
  92    2025-02-04 19:06    42  ***********************
  93    2025-02-04 20:05    43  ************************
 ...    ..(  5 skipped).    ..  ************************
  99    2025-02-05 01:59    43  ************************
 100    2025-02-05 02:58    42  ***********************
 ...    ..(  9 skipped).    ..  ***********************
 110    2025-02-05 12:48    42  ***********************
 111    2025-02-05 13:47    43  ************************
 112    2025-02-05 14:46    42  ***********************
 115    2025-02-05 17:43    42  ***********************
 116    2025-02-05 18:42    43  ************************
 117    2025-02-05 19:41    43  ************************
 118    2025-02-05 20:40    42  ***********************
 119    2025-02-05 21:39    43  ************************
 120    2025-02-05 22:38    42  ***********************
 121    2025-02-05 23:37    43  ************************
 122    2025-02-06 00:36    43  ************************
 123    2025-02-06 01:35    42  ***********************
 124    2025-02-06 02:34    43  ************************
 125    2025-02-06 03:33    42  ***********************
 ...    ..(  7 skipped).    ..  ***********************
   5    2025-02-06 11:25    42  ***********************
   6    2025-02-06 12:24    43  ************************
 ...    ..(  3 skipped).    ..  ************************
  10    2025-02-06 16:20    43  ************************
  11    2025-02-06 17:19    42  ***********************
  12    2025-02-06 18:18    42  ***********************
  13    2025-02-06 19:17    42  ***********************
  14    2025-02-06 20:16    43  ************************
  15    2025-02-06 21:15    43  ************************
  16    2025-02-06 22:14    43  ************************
  17    2025-02-06 23:13    42  ***********************
  23    2025-02-07 05:07    42  ***********************
  24    2025-02-07 06:06     ?  -
  25    2025-02-07 07:05    34  ***************
  26    2025-02-07 08:04     ?  -
  27    2025-02-07 09:03    35  ****************
  28    2025-02-07 10:02     ?  -
  29    2025-02-07 11:01    32  *************
  30    2025-02-07 12:00    42  ***********************
  40    2025-02-07 21:50    42  ***********************
  41    2025-02-07 22:49    43  ************************
  42    2025-02-07 23:48    43  ************************
  43    2025-02-08 00:47    43  ************************
  44    2025-02-08 01:46    44  *************************
 ...    ..(  2 skipped).    ..  *************************
  47    2025-02-08 04:43    44  *************************
  48    2025-02-08 05:42    45  **************************
  49    2025-02-08 06:41    44  *************************
  52    2025-02-08 09:38    44  *************************
  53    2025-02-08 10:37     ?  -
  54    2025-02-08 11:36    35  ****************
SCT Error Recovery Control:
           Read:    100 (10.0 seconds)
          Write:    100 (10.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             114  ---  Lifetime Power-On Resets
0x01  0x010  4           24232  ---  Power-on Hours
0x01  0x018  6    136381458686  ---  Logical Sectors Written
0x01  0x020  6      1653611555  ---  Number of Write Commands
0x01  0x028  6  11142957209313  ---  Logical Sectors Read
0x01  0x030  6       816635183  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           24026  ---  Spindle Motor Power-on Hours
0x03  0x010  4           24024  ---  Head Flying Hours
0x03  0x018  4            1128  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4              47  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4              23  ---  Resets Between Cmd Acceptance and Completion
0x04  0x018  4               0  -D-  Physical Element Status Changed
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              36  ---  Current Temperature
0x05  0x010  1              42  ---  Average Short Term Temperature
0x05  0x018  1              42  ---  Average Long Term Temperature
0x05  0x020  1              60  ---  Highest Temperature
0x05  0x028  1              27  ---  Lowest Temperature
0x05  0x030  1              57  ---  Highest Average Short Term Temperature
0x05  0x038  1              34  ---  Lowest Average Short Term Temperature
0x05  0x040  1              49  ---  Highest Average Long Term Temperature
0x05  0x048  1              42  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             482  ---  Number of Hardware Resets
0x06  0x010  4              65  ---  Number of ASR Events
0x06  0x018  4              75  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x008  7               0  ---  Vendor Specific
0xff  0x010  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
So it’s cable \ port sata problem?
It’s doing resilver on web again automatically after this. No problems now, but I’ll check, they may appear again later =(
UPD:
Resilver completed
  pool: Main_Pool_1
 state: ONLINE
  scan: resilvered 18.6G in 00:10:45 with 0 errors on Sat Feb  8 12:19:51 2025
        Main_Pool_1                               ONLINE       0     0     0
          mirror-0                                ONLINE       0     0     0
            de06f47c-23a6-493a-b209-ce6b485b758f  ONLINE       0     0     0
What does that mean exactly. Pretend I’m an idiot, it make communicating better.
I have 6 ports sata total. 5 occupied, 1 empty.
I moved the disk from the 5th to the first, free one.
That was smart. It means one of two things, either the one SATA port is bad, or more likely the cable is suspect. Recommend replacing the cabke and plugging back into the original port. See what happens. It doesn’t sound like a drive failure.
Yeah.
I’ll try it =)
But it’s very strange how it become SUDDENLY bad after 4 years 0_o
Yes, it does happen as crazy as it sounds. I won’t pretend to understand why.
