Need some help.
I followed this helpful video to get this working as my ISP has zero’d out my SOCKS5 connection speed with the catalog app:
However, I can’t seem to get past the “curl ip.me” part from the bash shell in the container. “Could not resolve host: ip.me” error.
Dockge shows the bittorrent client up and running, but I cannot access the web portal. I tried multiple ports but nothing. It just hangs. I don’t see anything being blocked by my firewall.
I am using OPNsense and all my DHCP setttings / gateways are working, and up until now I have never have a problem gettting an ip address anywhere in my network.
Does dockge need to be on a separate ip address to the Truenas instance? My Truenas has its own DHCP / gateway setting enabled?
Has anybody else figured this out? I suspect its because dockge is on the same ip address as Truenas and truenas hates this from previous experience.
Thanks!
