I’m not sure if this is memory leak related or not but after updating to DragonFish 24.04.1.1 and disabling by lru_gen fixes my system goes into la la land about every 24 hours. The main admin GUI goes unresponsive and I can’t login or ssh to the main system but all my virtual machines stay running without issue. Only the admin GUI and my apps go unresponsive. The only way to get back control is to remote power cycle the server.
We’ll need some data from around the time it goes haywire. Can you keep an htop or similar open to see if it is really memory / CPU related?
Baring that, a debug file and bug ticket will be helpful.
10-4 and roger roger. I’ll see what I can get. I’ve tried looking through the logs after I can get back in but I’m not seeing much. I caught it today right after it occurred and after a reboot all the reporting is just missing for when the issue occurs.
bug ticket created and debug uploaded
I just wanted to note, the lru_gen issue isn’t even specifically with ZFS and ARC; I’m running s3qlfs file system (which is a FUSE file system, not even kernel space or using any special kernel memory), it writes data into a cache then writes it back to a local filesystem all compressed and deduplicated (as the name suggests, s3qlfs supports Amazon S3 storage and other cloudy backends, but I’m using the “local” backend so it’s storing everything onto an ext4 filesystem in my case.)
Rather than specifically a bad interaction with ARC, I speculate lru_gen sees the disk I/O as most recently used and eventually the actual software I want to use is least recently used and gets swapped out. Whatever the cause it sure makes the system run like hell after a while.
