Hi all!,
Comming from my other post (Designing new system), but decided to spin up another one just for a “shorter” answer.
I have to layout 8-10, 10 TB drives for my server. This will be - at the moment - a purely backup repository with no direct access from the rest of the network, so no concurrent users and such.
I have 10 bays to play with (I have 12 LFFs, but need to leave some for future use), so here’s the question:
I have ordered 9, 10TB drives (Ultrastar HC330) and my plan is to use it in a RAIDZ2. As I need at least 60 TBs, now after a ton of reading, I’m exploring other options for increased performance, so as far as I can see, I can:
- Set a stripped RAIDZ1, aka RAID50, with 8 drives. That’s 60 TBs raw and double? the speed. However, RAIDZ1 with 10 TB drives makes me a little unconfortable.
- Buy another drive, set a stripped RAIDZ2, aka RAID60, with 10 drives, again, 60 TBs raw. I feel this is a bit overkill in terms of redundancy.
- Keep as it is, and make the 9 drive-wide RAIDZ2 and get 70 TBs raw.
The rest of the variables are “set”, 7 million office-like files, 10 Gbit connection.
Again this is for a backup repository, so I want to make it safe and redundant. The system will be replicated to another offsite system, but that’s for the next topic.
So any comments on this are welcome.
Thank you!
