[EPERM] Authentication error (535): b'Error: authentication failed, system busy'
I got this error when trying to set up mail with lark.
File “/usr/lib/python3/dist-packages/middlewared/plugins/mail.py”, line 376, in send_raw
server = self._get_smtp_server(config, message[‘timeout’], local_hostname=local_hostname)
File “/usr/lib/python3/dist-packages/middlewared/plugins/mail.py”, line 433, in _get_smtp_server
server.login(config[‘user’], config[‘pass’])
File “/usr/lib/python3.11/smtplib.py”, line 750, in login
raise last_exception
File “/usr/lib/python3.11/smtplib.py”, line 739, in login
(code, resp) = self.auth(
File “/usr/lib/python3.11/smtplib.py”, line 662, in auth
raise SMTPAuthenticationError(code, resp)
smtplib.SMTPAuthenticationError: (535, b’Error: authentication failed, system busy’)
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 509, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 556, in __run_body
rv = await self.middleware.run_in_thread(self.method, *args)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1367, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1364, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 183, in nf
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 55, in nf
res = f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/plugins/mail.py”, line 267, in send
return self.send_raw(job, message, config)
File “/usr/lib/python3/dist-packages/middlewared/plugins/mail.py”, line 395, in send_raw
raise CallError(
middlewared.service_exception.CallError: [EPERM] Authentication error (535): b’Error: authentication failed, system busy’
1st… always provide software version info
2nd… please do a search on sending mail from cli. there are security issues and so some complexity.
