LDAP configuration problem on Scale-24.10.1
Hello.
I build a new storage to test Scale ElectricEel-24.10.1 version.
When I try to configure the LDAP it fails.
I have 2x 23.10 and 2x 22.10 versions with the same ldap configuration they are working without any issue.
My ldap server is FreeIPA 4.11.0
Can you please help me on this?
FAILED
[EFAULT] Jan 08 16:15:39 systemd[1]: sssd.service - System Security Services Daemon was skipped because no trigger condition checks were met. Jan 10 00:22:01 systemd[1]: Starting sssd.service - System Security Services Daemon… Jan 10 00:22:01 sssd[48300]: SSSD couldn’t load the configuration database [1432158325]: Error while parsing configuration file Jan 10 00:22:01 systemd[1]: sssd.service: Main process exited, code=exited, status=4/NOPERMISSION Jan 10 00:22:01 systemd[1]: sssd.service: Failed with result ‘exit-code’. Jan 10 00:22:01 systemd[1]: Failed to start sssd.service
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 509, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 554, in __run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 49, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 179, in nf
File “/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py”, line 682, in do_update
await self.__start(job, ds_type)
File “/usr/lib/python3/dist-packages/middlewared/plugins/ldap.py”, line 971, in __start
cache_job_id = await self.middleware.call(‘directoryservices.connection.activate’)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1629, in call
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1471, in call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1364, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/directoryservices
/join.py", line 44, in activate
self.ipa_activate()
/ipa_join_mixin.py", line 133, in _ipa_activate
self.middleware.call_sync(‘service.start’, ‘sssd’, {‘silent’: False})
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1654, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1694, in run_coroutine
return fut.result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 449, in result
return self.__get_result()
File “/usr/lib/python3.11/concurrent/futures/_base.py”, line 401, in __get_result
raise self._exception
File “/usr/lib/python3/dist-packages/middlewared/plugins/service.py”, line 208, in start
raise CallError(await service_object.failure_logs() or ‘Service not running after start’)
middlewared.service_exception.CallError: [EFAULT] Jan 08 16:15:39 systemd[1]: sssd.service - System Security Services Daemon was skipped because no trigger condition checks were met.
Jan 10 00:22:01 systemd[1]: Failed to start sssd.service - System Security Services Daemon.
Jan 10 00:22:17 systemd[1]: Starting sssd.service - System Security Services Daemon…
Jan 10 00:22:17 sssd[48356]: SSSD couldn’t load the configuration database [1432158325]: Error while parsing configuration file
Jan 10 00:22:17 systemd[1]: sssd.service: Main process exited, code=exited, status=4/NOPERMISSION
Jan 10 00:22:17 systemd[1]: sssd.service: Failed with result ‘exit-code’.
Jan 10 00:22:17 systemd[1]: Failed to start sssd.service - System Security Services Daemon.
Jan 10 00:36:03 systemd[1]: Starting sssd.service - System Security Services Daemon…
Jan 10 00:36:03 sssd[48995]: SSSD couldn’t load the configuration database [1432158325]: Error while parsing configuration file
Jan 10 00:36:03 systemd[1]: sssd.service: Main process exited, code=exited, status=4/NOPERMISSION
Solution is:
On the 24.10 version LDAP requires these extra settings.
  • Kerberos Realms
  • Kerberos Keytab
