I am testing TrueNAS SCALE (version 24.04.0) deployed inside a KVM-based Virtual Private Server (VPS) host to analyze ZFS pool performance and disk passthrough behaviors.
Environment & Topology
OS Edition: TrueNAS SCALE 24.04.0
Deployment: KVM Hypervisor on VPSTTT infrastructure
Storage Topology: 4x 50GB virtual disks in RAIDZ1 pool (tank)
RAM: 16 GB allocated
Diagnostics & Context
During sequential I/O benchmarking using fio, the pool experienced I/O delay timeouts resulting in faulted virtual vdevs. Running zpool status indicates checksum mismatches under heavy load across virtual block devices (vda, vdb, vdc, vdd).
Question
What hypervisor I/O caching modes (e.g., none, writeback) and disk controller settings are optimal for maintaining ZFS pool integrity when hosting TrueNAS SCALE on KVM-based VPS backends?
Why would you expect any fundamental change in three years?
If the purpose is to play with the interface to test how it works, any hypervisor will do.
If the purpose is to host any actual data, or to get real numbers as here, the rules are simple: Type 1 hypervisor only and pass-through of the PCIe controller(s) of all data drives. Plus blacklisting said controllers if the hypervisor happens to be able to mount ZFS pools (Proxmox), which may not apply here.
For testing on hypervisor has always been fine, but there have been some stories on here when TrueNAS on a VM goes wrong. Putting TrueNAS on bare metal is always the preferred option.
This is my understanding, but saying that people have told me I am bonkers for virtualizing pfsense on my TrueNAS box, which by the way has been running fine for years except when the NIC failed.
Self-contradicting statement aside, it’s still very close to the truth–there are many variables that play into any decision, the effect of which is that any universal statement is almost certain to be wrong in some cases. When it comes to virtualizing TrueNAS, there are pitfalls that can eat your data if you do it wrong–but they’re well-known, and well-documented (JGreco wrote them up something like ten years ago; they’re nothing new), so they can readily be avoided with a modicum of care (i.e., RTFM).
So is TrueNAS on bare metal “always the preferred option”? I don’t think so. It’s simpler, and it’s safer (because the data-eating pitfalls aren’t there), but it makes your hardware less versatile. And sure, TrueNAS can run VMs, but it pales in comparison to something like Proxmox or xcp-ng in that regard (and I expect it always will, though sadly my crystal ball is in the shop).
Perhaps an unpopular opinion around here…If you are going to virtualize TrueNAS on a VPS, build a pool with a stripe of 1 disk. You need 1 disk for your OS and 1 disk for your pool.
The “disks” provided by your VPS aren’t hard drives, they are volumes carved out of a SAN with it’s own RAID. If one of the volumes goes down on your VPS, the chances are that all of them will. You have not gained anything by trying to do RAID in ZFS on top of their provided storage.
