Expand Mini-ITX PCI-E slots internally with oculink?
Are there any decent options to covert an oculink port into a well-secured, internal PCI-E slot?
It looks like most of the options available are meant for eGPU options.
My current hardware is currently constrained to a mini-ITX form factor for space reasons, and if situation that changes, I’d like to be able to upgrade my case and use additional PCI-e slots without having to replace the board by availing myself of some existing 8x oculink ports.
Thoughts?
Man, sounds too specific to case, motherboard, & connector. If you were using a specific enterprise vendor for everything then I’m sure there’d be a solution for sale, but I think you’re about to get very familiar with your preferred 3d modeling software of choice & a 3d printer :confused:
