Gradual Disk Replacement in RAIDZ1: Expanding Capacity from 2TB to 4TB
I currently have a RAIDZ1 array with three 1TB disks, giving me a total capacity of 2TB. Can I gradually replace each 1TB disk with a 2TB disk one by one, and after replacing all three disks, execute an expand operation to increase the total capacity to 4TB?
Yes. ZFS should even expand automatically without manual intervention.
If possible, do not physically remove the old drives until the replacement is complete. Plug in a new drive, replece an existing drive from the GUI, wait and the remove the drive which had been replaced (check serial number!). Rince and repeat.
ZFS has a zpool property to control auto expanding pools. TrueNAS sets it to on for non-boot pools and off for the boot-pool. So non-boot pools should auto-expand as soon as the space is available, while boot-pool should not.
admin@KrausHaus[~]$ /sbin/zpool get autoexpand
NAME       PROPERTY    VALUE   SOURCE
KH         autoexpand  on      local
VMs        autoexpand  on      local
boot-pool  autoexpand  off     default
admin@KrausHaus[~]$
This depends on a bunch of factors beyond just the autoexpand property.
So, if it doesn’t auto expand, then there is a button on the pool “expand” which should do the trick
Besides disk capacity and autoexpand property, what else does automatic expansion depend on?
One example is the size of the partition, and how different versions of TrueNAS have handled that differently.
