Hello!
I recently installed TrueNAS and noticed some issues with the gui. Several buttons and dropdown menus are not working. Like the power button on the dashboard doesn’t function. The menu still has options available but it is not visible, you can still use tab and the arrows to change options in the invisible menus.
This error code appears
‘failed to sync TRUENAS catalog: [EFUALT] Failed to clone ‘Ht tps://github.com/truenas/apps’ repository at ‘/var/run/middleware/ix-apps/catalogs’ destination: [EFUALT] Failed to clone ‘ht tps://github.com/truenas/apps’ repos At ‘var/run/middleware/ix-apps/catalogs’ destination: cloning into ‘/var/run/middleware/ix-…
This error message sounds unrelated to the gui issue but worth mentioning. The system is also completely airgapped and has not been connected to the internet before.
Thanks in advanced
