Hard drive degraded need help
I have a disk (ada0) that is degraded but it is still usable. I went and brought a new disk (ada1) and added ada1 as the mirror. Truenas resilvered successfully somehow. No data loss (yay!)
Now, I need some help. ada0 is still under warranty, so I want to remove it and send back to seller for a new one
Before that, I need to prove it. So need some help on this. I want to look at why it is degraded and is it enough for seller to give me a replacement.
Anyone know what is the approach? Is it something I can do on UI, or I must use the shell? I am not familiar with running the shell.
Screenshots:
You want to send them a screen or a copy of the smartctl error log after a long test. Do note that a checksum error on the GUI is not an indication of a drive failing.
Activate the SSH service, check your system’s hostname in the dashboard (see below), and then copy it.
Screenshot_1
Then open the CMD in windows and write ssh root@truenas.local (or your hostname if it’s different). It may ask you something, accept everything and log in with the root password.
Once you are inside and see something like the following message:
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
  1. Write tmux new and push enter.
  2. Write smartctl -t long /dev/ada0 or ada1 depending on which drive you want to RMA.
  3. Wait for the test to complete, it will take hours; you can close the CMD and do your things, as long as TN is not powered off or rebooted, the test will go on until completed.
  4. You can access back anytime with the CMD by following the same process and writing tmux attach instead of new.
  5. To check the progress, write smartctl -l selftest /dev/ada0: when the test is completed, you will see something like the following.
# 1  Extended offline    Completed without error       00%      2087         -
  1. Once completed, please post the output of smartctl -a /dev/ada0.
Thank you so much. Currently, i am waiting for it to finish.
Here is current progress:
root@truenas[~]# smartctl -l selftest /dev/ada0
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
# 1  Extended offline    Self-test routine in progress 90%     16067         -
# 2  Extended offline    Completed: read failure       10%     12342         3049407010
# 3  Extended offline    Completed: read failure       10%     12316         3055598006
# 4  Extended offline    Interrupted (host reset)      60%     12074         -
Of course, my experience with Seagate/WD is you just send them the drive that still in warranty and they just send another.
May be different in different countries.
@Stux
The warranty situation is a bit more complicated. The warrenty is actually with the seller. They sell harddrive that are out of warranty with the manufacturer.
@Davvo
I think the test is finished(?), since i see # 1 Extended offline Completed without error 00% 16075
Below result with smartctl -a /dev/ada0. It mentioned that the over health is “PASSED” - Does this mean the drive is actually fine? I don’t need to worry about DEGRADED?
root@truenas[~]# smartctl -a /dev/ada0
Model Family:     Western Digital Re
Device Model:     WDC WD4000FYYZ-05UL1B0
Serial Number:    WD-WMC130E9ED5P
LU WWN Device Id: 5 0014ee 00400a8b1
Firmware Version: 00.0NS05
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Apr 16 08:03:02 2024 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (47580) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
SMART capabilities:            (0x0003)
Short self-test routine
Extended self-test routine
recommended polling time:        ( 514) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   236   236   021    Pre-fail  Always       -       7200
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       43
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   078   078   000    Old_age   Always       -       16084
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       42
 16 Total_LBAs_Read         0x0022   000   200   000    Old_age   Always       -       14720125016
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       31
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       11
194 Temperature_Celsius     0x0022   108   103   000    Old_age   Always       -       44
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       19
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     16075         -
2 of 2 failed self-tests are outdated by newer successful extended offline self-test # 1
I also forgot to mention. I get these email alert from the nas:
TrueNAS @ truenas.local
The following alert has been cleared:
* Pool mypool state is DEGRADED: One or more devices has experienced an error
resulting in data corruption. Applications may be affected.
The following devices are not healthy:
* Disk WDC WD4000FYYZ-05UL1B0 WD-WMC130E9ED5P is DEGRADED
Current alerts:
* Device: /dev/ada0, Self-Test Log error count increased from 0 to 1.
* The following system core files were found: rrdcached.core. Please create a
ticket at https://ixsystems.atlassian.net/ and attach the relevant core files
along with a system debug. Once the core files have been archived and attached
to the ticket, they may be removed by running the following command in shell:
'rm /var/db/system/cores/*'.
Also in the Truenas UI alert:
Pool mypool state is DEGRADED: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
That means you are not out of the woods yet…
There are no bad sectors (pending/reallocated) but non-zero Multi-Zone is not good. This could be a bad cable or a misbehaving controller though.
What’s the output of zpool status -v mypool ?
No, it just means the drive was able to complete the test.
This should be enough for and RMA under most warranties, especially if coupled with the previous test failures.
@Davvo
Thanks you so much. I will contact the seller.
@etorix
Here is the output of zpool status -v mypool. This does look worrying.
root@truenas[~]# zpool status -v mypool
  pool: mypool
 state: DEGRADED
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: resilvered 530G in 03:52:00 with 20 errors on Sun Apr 14 15:30:14 2024
        mypool                                          DEGRADED     0     0     0
          mirror-0                                      DEGRADED     0     0     0
            gptid/ae061260-743a-11ee-84ff-1c6f65f98779  DEGRADED     0     0    40  too many errors
            gptid/26b96453-fa8e-11ee-8173-1c6f65f98779  ONLINE       0     0    40
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/nfsstat-client/nfsstat-mkdir.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/df-mnt-mypool-J/df_complex-reserved.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/zfs_arc/cache_size-mru_ghost_size.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/zfs_arc_v2/gauge_arcstats_raw_hash-hash_collisions.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cpu-2/cpu-interrupt.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cpu-2/cpu-nice.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cpu-4/cpu-idle.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cpu-4/cpu-user.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cpu-5/cpu-idle.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cpu-5/cpu-user.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cpu-6/cpu-user.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/cputemp-3/temperature.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/ctl-tpc/disk_time-0-0.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/df-mnt-mypool-J/df_complex-free.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/df-mnt-mypool-J/df_complex-used.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/disktemp-ada0/temperature.rrd
        mypool/.system/rrd-b85043590a434da692c02c2416a40e36:/localhost/disktemp-ada1/temperature.rrd
The good point is that errors are all in the system dataset, not in your actual data.
The bad point is that there’s a hardware issue in the wild.
@etorix
Thanks for checking. In any case, I already contacted the seller, hopefully they would give me replacement or refund.
That should be enough for an RMA
Additionally, I strongly suggest setting up periodic long tests on all your drives in order to not get the short stick all of a sudden. You can do so on the WebUI.
I use weekly long tests (and daily short ones, but I am a bit overzealous) alongside @joeschmuck’s Multi-Report.
Same schedule here. Short tests are a matter of minutes, so there’s nothing outlandish in doing these often.
