There are multiple issues here. As for Plex and k3s, the best solution is to start anew with Docker on Electric Eel, so we might skip that and worry about recovering this pool.
This is not enough to understand what you did and how bad the damage might be.
What commands? For what output?
So you deleted potentially relevant error messages, but do not disclose what these were.
Full hardware description and full output of sudo zpool status and sudo zpool import within triple backticks (``` , </> button) please. lsblk and smartctl -x /dev/sdX for the degraded disk would also be of relevance.
Pentium G645
8GB DDR3 Ram
450W PSU
2TB Seagate Skyhawk Lite Hard disk
250GB Seagate Barracuda Hard Disk (Boot drive)
It was running in stripe
TAG Gigabit Ethernet NIC
root@truenas[~]# sudo zpool status
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:49 with 0 errors on Mon Nov 18 03:45:51 2024
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
sdb3 ONLINE 0 0 0
errors: No known data errors
root@truenas[~]# sudo zpool import
pool: pool
state: ONLINE
action: The pool can be imported using its name or numeric identifier.
pool ONLINE
a2128238-1379-4f3f-8211-940f1fca2992 ONLINE
root@truenas[~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 1.8T 0 disk
└─sda1 8:1 0 1.8T 0 part
sdb 8:16 0 232.9G 0 disk
├─sdb1 8:17 0 1M 0 part
├─sdb2 8:18 0 512M 0 part
├─sdb3 8:19 0 216.4G 0 part
└─sdb4 8:20 0 16G 0 part
└─sdb4 253:0 0 16G 0 crypt
root@truenas[~]# smartctl -x /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.32-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: ST2000VX007-2AY102
Serial Number: ZFM0D09T
LU WWN Device Id: 5 000c50 0b5cd3949
Firmware Version: CV11
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5425 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue Nov 19 04:40:27 2024 PST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 246) minutes.
Conveyance self-test routine
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 083 064 006 - 181484721
3 Spin_Up_Time PO---- 097 097 000 - 0
4 Start_Stop_Count -O--CK 089 089 020 - 11560
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 090 060 045 - 1109332624
9 Power_On_Hours -O--CK 071 071 000 - 25828
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 097 097 020 - 3078
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 099 000 - 14
189 High_Fly_Writes -O-RCK 100 100 000 - 0
190 Airflow_Temperature_Cel -O---K 061 054 040 - 39 (Min/Max 38/40)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 23
192 Power-Off_Retract_Count -O--CK 100 100 000 - 351
193 Load_Cycle_Count -O--CK 085 085 000 - 30487
194 Temperature_Celsius -O---K 039 046 000 - 39 (0 23 0 0 0)
195 Hardware_ECC_Recovered -O-RC- 083 064 000 - 181484721
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
240 Head_Flying_Hours ------ 100 253 000 - 19995 (54 96 0)
241 Total_LBAs_Written ------ 100 253 000 - 59903651475
242 Total_LBAs_Read ------ 100 253 000 - 57973833246
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x04 GPL,SL R/O 8 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 2048 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x24 GPL R/O 512 Current Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 24 Device vendor specific log
0xa2 GPL VS 8160 Device vendor specific log
0xa6 GPL VS 192 Device vendor specific log
0xa8-0xa9 GPL,SL VS 136 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xb0 GPL VS 9048 Device vendor specific log
0xbd GPL VS 8 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL,SL VS 16 Device vendor specific log
0xc3 GPL,SL VS 8 Device vendor specific log
0xc4 GPL,SL VS 24 Device vendor specific log
0xd1 GPL VS 264 Device vendor specific log
0xd3 GPL VS 1920 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
Device State: Active (0)
Current Temperature: 39 Celsius
Power Cycle Min/Max Temperature: 38/40 Celsius
Lifetime Min/Max Temperature: 23/46 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 3 minutes
Temperature Logging Interval: 94 minutes
Min/Max recommended Temperature: 1/61 Celsius
Min/Max Temperature Limit: 2/60 Celsius
Temperature History Size (Index): 128 (43)
Index Estimated Time Temperature Celsius
44 2024-11-10 20:32 40 *********************
45 2024-11-10 22:06 40 *********************
46 2024-11-10 23:40 40 *********************
47 2024-11-11 01:14 39 ********************
48 2024-11-11 02:48 40 *********************
49 2024-11-11 04:22 41 **********************
50 2024-11-11 05:56 41 **********************
51 2024-11-11 07:30 42 ***********************
... ..( 2 skipped). .. ***********************
54 2024-11-11 12:12 42 ***********************
55 2024-11-11 13:46 41 **********************
56 2024-11-11 15:20 41 **********************
57 2024-11-11 16:54 41 **********************
58 2024-11-11 18:28 40 *********************
59 2024-11-11 20:02 40 *********************
60 2024-11-11 21:36 40 *********************
61 2024-11-11 23:10 39 ********************
62 2024-11-12 00:44 39 ********************
63 2024-11-12 02:18 40 *********************
64 2024-11-12 03:52 41 **********************
65 2024-11-12 05:26 41 **********************
66 2024-11-12 07:00 42 ***********************
69 2024-11-12 11:42 42 ***********************
70 2024-11-12 13:16 41 **********************
71 2024-11-12 14:50 41 **********************
72 2024-11-12 16:24 40 *********************
75 2024-11-12 21:06 40 *********************
76 2024-11-12 22:40 ? -
77 2024-11-13 00:14 32 *************
78 2024-11-13 01:48 41 **********************
79 2024-11-13 03:22 41 **********************
80 2024-11-13 04:56 41 **********************
81 2024-11-13 06:30 40 *********************
84 2024-11-13 11:12 40 *********************
85 2024-11-13 12:46 39 ********************
88 2024-11-13 17:28 39 ********************
89 2024-11-13 19:02 ? -
90 2024-11-13 20:36 30 ***********
91 2024-11-13 22:10 40 *********************
92 2024-11-13 23:44 40 *********************
93 2024-11-14 01:18 39 ********************
... ..( 4 skipped). .. ********************
98 2024-11-14 09:08 39 ********************
99 2024-11-14 10:42 40 *********************
100 2024-11-14 12:16 41 **********************
101 2024-11-14 13:50 41 **********************
102 2024-11-14 15:24 40 *********************
103 2024-11-14 16:58 41 **********************
104 2024-11-14 18:32 40 *********************
105 2024-11-14 20:06 ? -
106 2024-11-14 21:40 30 ***********
107 2024-11-14 23:14 40 *********************
108 2024-11-15 00:48 39 ********************
... ..( 3 skipped). .. ********************
112 2024-11-15 07:04 39 ********************
113 2024-11-15 08:38 38 *******************
114 2024-11-15 10:12 39 ********************
115 2024-11-15 11:46 40 *********************
116 2024-11-15 13:20 40 *********************
117 2024-11-15 14:54 40 *********************
118 2024-11-15 16:28 ? -
119 2024-11-15 18:02 31 ************
120 2024-11-15 19:36 41 **********************
121 2024-11-15 21:10 41 **********************
122 2024-11-15 22:44 40 *********************
123 2024-11-16 00:18 40 *********************
124 2024-11-16 01:52 40 *********************
125 2024-11-16 03:26 39 ********************
0 2024-11-16 08:08 39 ********************
1 2024-11-16 09:42 38 *******************
2 2024-11-16 11:16 38 *******************
3 2024-11-16 12:50 39 ********************
4 2024-11-16 14:24 39 ********************
5 2024-11-16 15:58 40 *********************
6 2024-11-16 17:32 ? -
7 2024-11-16 19:06 43 ************************
8 2024-11-16 20:40 ? -
9 2024-11-16 22:14 43 ************************
10 2024-11-16 23:48 ? -
11 2024-11-17 01:22 43 ************************
12 2024-11-17 02:56 ? -
13 2024-11-17 04:30 43 ************************
14 2024-11-17 06:04 ? -
15 2024-11-17 07:38 43 ************************
16 2024-11-17 09:12 ? -
17 2024-11-17 10:46 43 ************************
18 2024-11-17 12:20 ? -
19 2024-11-17 13:54 43 ************************
20 2024-11-17 15:28 ? -
21 2024-11-17 17:02 43 ************************
22 2024-11-17 18:36 ? -
23 2024-11-17 20:10 43 ************************
24 2024-11-17 21:44 ? -
25 2024-11-17 23:18 43 ************************
26 2024-11-18 00:52 ? -
27 2024-11-18 02:26 37 ******************
28 2024-11-18 04:00 ? -
29 2024-11-18 05:34 37 ******************
30 2024-11-18 07:08 ? -
31 2024-11-18 08:42 37 ******************
32 2024-11-18 10:16 ? -
33 2024-11-18 11:50 37 ******************
34 2024-11-18 13:24 ? -
35 2024-11-18 14:58 37 ******************
36 2024-11-18 16:32 ? -
37 2024-11-18 18:06 37 ******************
38 2024-11-18 19:40 ? -
39 2024-11-18 21:14 37 ******************
40 2024-11-18 22:48 ? -
41 2024-11-19 00:22 39 ********************
42 2024-11-19 01:56 ? -
43 2024-11-19 03:30 40 *********************
SCT Error Recovery Control:
Read: Disabled
Write: Disabled
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 3078 --- Lifetime Power-On Resets
0x01 0x010 4 25828 --- Power-on Hours
0x01 0x018 6 59912285538 --- Logical Sectors Written
0x01 0x020 6 906250956 --- Number of Write Commands
0x01 0x028 6 57990686594 --- Logical Sectors Read
0x01 0x030 6 709711678 --- Number of Read Commands
0x01 0x038 6 - --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 22771 --- Spindle Motor Power-on Hours
0x03 0x010 4 20395 --- Head Flying Hours
0x03 0x018 4 30487 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x03 0x038 4 0 --- Number of Realloc. Candidate Logical Sectors
0x03 0x040 4 351 --- Number of High Priority Unload Events
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 1 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 11 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 39 --- Current Temperature
0x05 0x010 1 39 --- Average Short Term Temperature
0x05 0x018 1 39 --- Average Long Term Temperature
0x05 0x020 1 46 --- Highest Temperature
0x05 0x028 1 0 --- Lowest Temperature
0x05 0x030 1 43 --- Highest Average Short Term Temperature
0x05 0x038 1 31 --- Lowest Average Short Term Temperature
0x05 0x040 1 40 --- Highest Average Long Term Temperature
0x05 0x048 1 32 --- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 70 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 8050 --- Number of Hardware Resets
0x06 0x010 4 845 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 9 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
Seagate FARM log (GP Log 0xa6) supported [try: -l farm]
I got impatient and i tried to do a recovery using hetman partition recovery tool on windows but i stopped that and plugged it back into the nas because you replied
