Hello
I am new to NAS systems.
I want to build an energy-efficient NAS.
The plan is to use TrueNAS Scale with 2x12TB and maybe later upgrade to 4x12TB. I would operate this in RAID 1, then after the upgrade in Raid 10.
I was thinking about maybe using an ASRock N100M and if I plan to upgrade to a PCIe 3.0x1 to 2x SATA adapter is that even possible or am I missing something.
Or should something more powerful be used such as Intel Core i3-12100T/10100/… Then the problem with the Sata ports would no longer be a problem.
I would use a small NVME SSD on which I install TrueNAS Scale.
Which 12TB HDDs would you use?
Your two drives would be Mirrored and then you would be adding a second VDEV of two drives Mirrored all in one pool. We don’t use the terms RAID 1 nor 10.
It’s best to pick a motherboard with enough SATA ports for your disks and avoid SATA expanders. Some may work, others fail with ZFS / TrueNAS.
Stick to NAS type hard drives that use CMR for recording tech. Avoid any drives listing SMR.
BASICS
iX Systems pool layout whitepaper
You can also see some builds in the Resources categories.
