I am running a virtualized (in Proxmox) Truenas scale server (Dragonfish-24.04.2.5) and I am running out of disk space in this Truenas scale server.
So I took the following steps (Zpool called: Safe, old size: 1GB, new size 1.5Gb)
- I shutdown the VM
- Enlarged the disk in the Proxmox interface from 1 to 1,5GB
- Started the Truenasscale VM in Proxmox
- In a treunasscale shell performed:
zpool -v set autoexpand=on Safe
- Also started a scrub from the UI (finished with no errors)
This did not make available the additional 0.5 GB. (in the Truenasscale UI the disk is shown as 1.5Gb)
How should I “unlock” this additional space? I hope to do this online, but if needed I can also boot into a liveCD. I would like to avoid copying all the data to a new disk…
Additional information:
root@truenasscale[~]# zpool list
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
Safe 997G 774G 223G - 501G 41% 77% 1.00x ONLINE /mnt
boot-pool 19G 15.6G 3.43G - - 42% 81% 1.00x ONLINE -
root@truenasscale[~]# fdisk -l
Disk /dev/sda: 20 GiB, 21474836480 bytes, 41943040 sectors
Disk model: QEMU HARDDISK
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: EC9A3B2D-3C84-4E2C-9838-C8A9AF33A46E
Device Start End Sectors Size Type
/dev/sda1 4096 6143 2048 1M BIOS boot
/dev/sda2 6144 1054719 1048576 512M EFI System
/dev/sda3 1054720 41943006 40888287 19.5G Solaris /usr & Apple ZFS
GPT PMBR size mismatch (2097151999 != 3145727999) will be corrected by write.
The backup GPT table is not on the end of the device.
Disk /dev/sdb: 1.46 TiB, 1610612736000 bytes, 3145728000 sectors
Disklabel type: gpt
Disk identifier: DABFA12F-48A0-4D7D-B536-9EAAAA835F08
/dev/sdb1 128 4194304 4194177 2G Linux swap
/dev/sdb2 4194432 2097151966 2092957535 998G Solaris /usr & Apple ZFS
Disk /dev/mapper/sdb1: 2 GiB, 2147418624 bytes, 4194177 sectors
root@truenasscale[~]# mount | grep /mnt
boot-pool/ROOT/24.04.2.5/mnt on /mnt type zfs (rw,relatime,xattr,noacl,casesensitive)
Safe on /mnt/Safe type zfs (rw,noatime,xattr,posixacl,casesensitive)
Safe/Media on /mnt/Safe/Media type zfs (rw,noatime,xattr,posixacl,casesensitive)
Safe/FTP on /mnt/Safe/FTP type zfs (rw,noatime,xattr,posixacl,casesensitive)
Safe/Music on /mnt/Safe/Music type zfs (rw,noatime,xattr,posixacl,casesensitive)
Safe/Photos on /mnt/Safe/Photos type zfs (rw,noatime,xattr,posixacl,casesensitive)
