How to fix ZFS Error?
Been running Truenas for years now this is the first time I got a ZFS Error without have a drive showing smart errors. How do I correct this?
Extra info
I just finish a short smart test on the drive and running a long smart test will post results
OS ElectricEel-24.10.1
truenas[~]$ sudo zpool status
pool: NVME Storage
state: ONLINE
action: Enable all features using ‘zpool upgrade’. Once this is done,
scan: scrub repaired 0B in 00:00:03 with 0 errors on Wed Jan 15 04:00:04 2025
    NAME                                    STATE     READ WRITE CKSUM
    NVME Storage                            ONLINE       0     0     0
      0e8a3c51-ce34-4780-b326-021d71fb87bb  ONLINE       0     0     0
errors: No known data errors
pool: RaidZ1
state: ONLINE
scan: scrub repaired 0B in 00:45:19 with 0 errors on Sun Dec 29 00:45:32 2024
    RaidZ1                                    ONLINE       0     0     0
      raidz1-0                                ONLINE       0     0     0
        b5681268-d393-43bb-8780-de8df4e6a916  ONLINE       0     0     0
        0f30667c-e682-11eb-9f56-3cecef778c94  ONLINE       0     0     0
        0f336ce4-e682-11eb-9f56-3cecef778c94  ONLINE       0     0     0
        0f31b5bd-e682-11eb-9f56-3cecef778c94  ONLINE       0     0     0
        0f370c2b-e682-11eb-9f56-3cecef778c94  ONLINE       0     0     0
pool: SuperRaidZ1
state: ONLINE
status: One or more devices are faulted in response to persistent errors.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Replace the faulted device, or use ‘zpool clear’ to mark the device
repaired.
scan: scrub repaired 0B in 1 days 04:44:22 with 0 errors on Thu Jan 16 08:44:2 4 2025
    SuperRaidZ1                               ONLINE       0     0     0
        cd4d887a-07a7-4bd0-b583-18d551243025  ONLINE       0     0     0
        3c6dc06a-776d-43d2-b527-8d566ba39206  ONLINE       0     0     0
        ea023cd1-b6d2-4885-a632-3f6192be34cd  ONLINE       0     0     0
        a50c082b-5f80-4b1f-9d2c-a50b7df1f51f  ONLINE       0     0     0
        dea983cf-7b20-45da-a6ff-4ebbd55a942e  ONLINE       0     0     0
      raidz1-4                                ONLINE       0     0     0
        8421bc86-df35-4280-b10f-961748457bdf  ONLINE       0     0     0
        3925170a-74f8-4fb1-972d-d09a79c7024c  FAULTED    532   580     0  to        o many errors
        e607e354-26eb-484f-ab39-ba2fbfe86c5a  ONLINE       0     0     0
        8ed7d72b-d3cc-4022-94a6-58593ef10559  ONLINE       0     0     0
        1a824df6-c46a-4e4c-b3e5-6a3843986581  ONLINE       0     0     0
    logs
      b5727936-6bec-48bf-bcda-f9ca5255ebe3    ONLINE       0     0     0
    cache
      nvme0n1p1                               ONLINE       0     0     0
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:19 with 0 errors on Mon Jan 13 03:45:20 2025
      sdh3      ONLINE       0     0     0
I think atm you have to assume that drive has failed and needs replacing. If you have a suitable spare then begin the replacement process asap. If not then get one ordered asap. Make a note of its physical location so that if your replacement drives suffers the same issue then you will need to carry out further investigation into that slot to see if there is any cable issues.
I got a spare drive just incase but I think the drive is fine here the smart test results after doing a long test.
Device Model: WDC WD180EDGZ-11BLDS0
Serial Number: 8LHEXMJK
LU WWN Device Id: 5 000cca 2c7d46bcd
Firmware Version: 85.00A85
User Capacity: 18,000,207,937,536 bytes [18.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5528
ATA Version is: ACS-5 (minor revision not indicated)
SATA Version is: SATA 3.5, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Jan 17 16:46:55 2025 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off supp ort.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (2220) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
2 Throughput_Performance 0x0004 145 145 000 Old_age Offline - 61
3 Spin_Up_Time 0x0007 093 093 001 Pre-fail Always - 217 (Average 126)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 89
5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 100 000 Old_age Always - 0
8 Seek_Time_Performance 0x0004 140 140 000 Old_age Offline - 15
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 9542
10 Spin_Retry_Count 0x0012 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 89
22 Unknown_Attribute 0x0023 100 100 025 Pre-fail Always - 6553700
90 Unknown_Attribute 0x0031 100 100 001 Pre-fail Offline - 283467841536
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 609
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 609
194 Temperature_Celsius 0x0002 035 035 000 Old_age Always - 43 (Min/Max 24/59)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
1 Extended offline Completed without error 00% 9538 -
2 Short offline Completed without error 00% 9512 -
3 Short offline Completed without error 00% 9409 -
4 Short offline Completed without error 00% 9241 -
5 Short offline Completed without error 00% 9001 -
6 Short offline Completed without error 00% 8833 -
7 Short offline Completed without error 00% 8665 -
8 Extended offline Completed without error 00% 8554 -
9 Short offline Completed without error 00% 8497 -
#10 Short offline Completed without error 00% 8281 -
#11 Short offline Completed without error 00% 8129 -
#12 Short offline Completed without error 00% 8072 -
#13 Short offline Completed without error 00% 7870 -
#14 Extended offline Completed without error 00% 7809 -
#15 Short offline Completed without error 00% 7702 -
#16 Short offline Completed without error 00% 7534 -
#17 Extended offline Completed without error 00% 7424 -
#18 Short offline Completed without error 00% 7366 -
#19 Short offline Completed without error 00% 7126 -
#20 Extended offline Completed without error 00% 7063 -
#21 Short offline Completed without error 00% 6958 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The above only provides legacy SMART information - try ‘smartctl -x’ for more
