Immich on EE 24.10
Trying to install immich on EE 24.10 EC2… I am using pre-created datasets for the folders.
Everything seems to work EXCEPT the postgres folder.
  • If I use the pre-created dataset folder for that I always get the error below.
  • If I allow the system to create its own data set (ixVolume) at install time, it works OK.
I’ve tried fiddling with the dataset permissions a zillion times with no progress.
Any tips/thoughts?
Error I see when trying to install immich:
[EFAULT] Failed ‘up’ action for ‘immich’ app, please check /var/log/app_lifecycle.log for more details
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 488, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 535, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1363, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1360, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 268, in nf
    rv = func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 203, in do_create
    return self.create_internal(job, app_name, version, data['values'], complete_app_details)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 252, in create_internal
    raise e from None
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 240, in create_internal
    compose_action(app_name, version, 'up', force_recreate=True, remove_orphans=True)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/compose_utils.py", line 57, in compose_action
    raise CallError(
middlewared.service_exception.CallError: [EFAULT] Failed 'up' action for 'immich' app, please check /var/log/app_lifecycle.log for more details
Manually fixed it with this tip (manually change dataset owner to netdata):
