Iocage jail creation: releases not presented in dropdown
I am running TrueNAS Core 13.0-U6.7. When I try to create a new jail there are no releases presented in the dropdown, either for clone jail or base jail. The releases seem to be there in the iocage/releases dataset. There are 13.0, 13.1, 13.5 and older ones as well and there is a root dataset inside each one containing files.
Iocage and zfs can see the releases. I.e.:
iocage list -r
zfs list -r /iocage/releases
Is this because FreeBSD 13.1 is end of life or something? I thought I could create jails as long as I have the release files downloaded already even though my installation is oldish.
I’m absolutely no expert for bsd jails but I believe you’d have to update to core 13.3 via manual update file to create new jails
hmm. I wonder if that might be risky. IX says that jails aren’t supported anymore in 13.3…?
@HoneyBadger Are new Jail creations EOL on Core. I thought we lost that when FreeBSD 13 series went EOL.
Staying on CORE at all is risky. The entire series is EOL, and it’s based on an OS that’s also EOL. If you want to stay with a FreeBSD-based NAS, it’s long past time you moved away from TrueNAS (if you want to stay as close as possible to TrueNAS, FreeCORE is an option). If you want to stay with TrueNAS, you really need to be using SCALE/CE.
It’s just an non-exposedisolated instance in my home LAN. That said, the reason I haven’t moved to Scale yet is that I still cannot grasp (or have had time to get into the weeds) of how to create Linux containers that can replace my nextcloud and web development jails with the same benefits as jails (snapshot rollback, persistence, isolation). Perhaps over Xmas holidays…
I’d wait for the release of truenas 27 then because the backend that runs the lxc container will change with the next release in december
I had the exact same issue after so many years of FreeBSD. I had a test-server with TrueNAS CE to eventually migrate my main server to CE(Scale) but couldn’t get the hang of it.
I recommend you have a look at FreeCORE. I converted my 13.3-RELEASE install to FreeCORE 15.1-RELEASE and it is everything that TrueNAS Core was and more and that on the latest FreeBSD release which allows you to bring all your jails in the present time. It even has an option to revert back to TrueNAS Core 13.3-RELEASE if you don’t like it or even allows you to convert to TrueNAS CE but i am pretty sure you won’t.
Thanks for the tip about FreeCORE. Looks interesting indeed. I will absolutely keep an eye on that project.
