Issue with USB Passthrough and ls /dev/serial/by-id :No such file or directory command under truenas scale 24.10.0.2 home assistant
hi,
here is my configuration to understand a firmware compatibility problem:
distribution: truenas scale 24.10.0.2
a VM home assistant
with a zigbee key deconz conbee 3 on USB port in PCI Passthrough Device
I didn’t understand why you wanted to run a keyboard in the setup console to do a reboot or change local administrator password and also why it is impossible to find the path/dev/serial/by-id. And after days of months to do several installation manipulations, I already found out what it was coming from. once you have configured the USB drive as a passthrough device and started the vm home assistant.
so when I stop the vm home assistant I find the path /dev/serial/by-id
which tells me the name of my key conbee 3 and I also inserted a conbee 2 that found me too. and the keyboard in console setup can allow changes.
here someone is the solution will be welcome
or help on this problem that often comes up
sorry my English and bad because I use a translator
