Conbee usb Passthrough - Home Assistant VM
Hi, i’m new to trunas scale but i succesfully installed Home assistant OS in a VM and works great but i cannot in any way get my Conbee II to work with Deconz
I’ve setup usb Passthrough trying all the controller types but the best that i can achieve is:
conbee is recognised in home assistant hardware and deconz but i get constantly “failed to reconnect to network try=1” on deconz registry
I cant add any sensor or switches and i find strange that in gateway setting the zigbee channel is set to 0 and the network id is unkown
I’ve tried to Passthrough the pci-controller for the usb but i can’t because my i5-4670K doesn’t support vt-d and i get “Unable to determine iommu group” error
Some advices?
Hey there, I registered in this forum just to reply to your post!
Have you ever manage to fix this issue? Because that’s exactly the problem I’m facing right now.
Conbee II stick connected via usb 2 to my truenas-host, usb-passthrough for every possible controller type and still no luck in home assistant.
The conbee stick gets recognized, but I cannot connect to it in any way (zha or deconz).
I tested this stick on my Windows-PC and from there everything works fine, so it has to be something on the truenas-host.
Any help would be highly appreciated, as my RasPi 3 just retired itself. :smiley:
