Hi everyone,
I’m running TrueNAS SCALE on a Dell PowerEdge R630. Here’s my setup:
1x 480GB SSD for the system
7x 480GB SSDs for data (planning to use RAID)
AMD Radeon PRO WX5100 GPU (I don’t want to passthrough it to a VM, just use it with Docker apps like Plex, Jellyfin, etc.)
I’m currently using SCALE version 24.10.1, and I noticed there’s a newer version (25.10). Is there any significant difference between these versions? Is it worth upgrading?
Now, here are the problems I’m facing:
- GPU Not Detected in Docker The GPU doesn’t show up in Docker apps. I only want to use it for Plex, Jellyfin, and similar apps — no VM passthrough. I expected it to show up in Docker, but it doesn’t. Do I need to manually assign render and video permissions to apps or users? Any step-by-step guide would be helpful.
- Docker Shell Limitations I created a non-root user (named “serwer”) with admin rights, because I didn’t want to use root. I use this account for SMB/FTP and transferring media files. However, when I try to use Shell, many commands like apt or others are not available. Is this normal on TrueNAS SCALE?
- FTP with SSL is Extremely Slow I set up FTP with SSL, but accessing directories takes forever or doesn’t work at all. Passive mode (PASV) is configured. When I disable SSL, everything works instantly. Why does SSL slow it down so much? Firewall is open for the PASV range. Is there a better way?
- RAID Not Working as Expected I tried to create a RAID with the 7x480GB SSDs, but it’s not behaving as expected. I want to mount the pool under /home and assign it to my non-root user. What’s the proper way to set this up?
- App Permissions Confusion Apps like Nextcloud, Jellyfin, and Plex can’t always access the folders I want them to. Do I need to manually assign groups like apps, media, render, etc. to my user? It’s confusing.
- Additional Notes on SMB and FTP On the system level, everything works fine and smoothly — however:
I noticed SMBv1 is very insecure and should never be used (especially with Windows).
I’m trying to use SMBv2 or SMBv3, which should work fine with antivirus software on client devices — but sometimes I don’t see any warning or info if SMB is being blocked or degraded.
FTP in general works well without SSL, but FTPS (FTP over SSL) is very slow, especially when reading directory listings.
I know SFTP (via SSH) is a better and more secure alternative, but I wasn’t sure if it’s supported out of the box in TrueNAS SCALE.
So the goal is: everything should work reliably across devices, including SMB (preferably v3) and FTP access with secure options, and GPU support for Docker (not VMs). If you have any ideas, tips, or guides to recommend — I would really appreciate it!
Thanks in advance!
