I need some help installing something on my TrueNAS Scale server, and I’d like to talk some things over (backup options, other best practices I may be lacking in, etc
Is there someone (or a list somewhere) that I can contact for help?
It’s kind of urgent
Thanks!
GROOT: Dell R740 | 2x Xeon GOld 6150 | 384GB ECC Ram (12x32GB) | 10TB SSD Pool | 100TB Rusty Pool
Depending on how much it is worth to you:
If you’re looking for a freelance for (maybe) cheaper support - no clue. Donno what iX would charge, but expect enterprise level support for enterprise cost.
//Edit: otherwise since you mentioned a list I’m going to post @ChrisRJ’s list:
TrueNAS Scale for beginners: https://www.truenas.com/community/resources/welcome-to-truenas-scale-beginners-intro.208/
ZFS Introduction: https://www.truenas.com/community/resources/introduction-to-zfs.111/
ZFS pool layout: https://www.truenas.com/community/resources/zfs-storage-pool-layout.201/
Hardware recommendations: https://www.truenas.com/community/resources/hardware-recommendations-guide.12/
Terminology and Abbreviations Primer: https://www.truenas.com/community/threads/terminology-and-abbreviations-primer.28174/
ECC RAM: https://www.truenas.com/community/threads/ecc-vs-non-ecc-ram-and-zfs.15449/
Don’t use RAID: https://www.truenas.com/community/resources/whats-all-the-noise-about-hbas-and-why-cant-i-use-a-raid-controller.139/
SATA controllers: https://www.truenas.com/community/resources/multiply-your-problems-with-sata-port-multipliers-and-cheap-sata-controllers.177/
List of SMR drives: https://www.truenas.com/community/resources/list-of-known-smr-drives.141/
Power supplies: https://www.truenas.com/community/resources/proper-power-supply-sizing-guidance.39/
Partitioning the boot drive: https://www.truenas.com/community/resources/i-have-to-waste-an-entire-drive-just-for-booting.187/
USB drives: https://www.truenas.com/community/resources/why-you-should-avoid-usb-attached-drives-for-pool-disks.190/
ZIL and SLOG: https://www.truenas.com/community/threads/some-insights-into-slog-zil-with-zfs-on-freenas.13633/
Block storage: https://www.truenas.com/community/threads/the-path-to-success-for-block-storage.81165/
SAS and SATA: https://www.truenas.com/community/resources/dont-be-afraid-to-be-sas-sy-a-primer-on-basic-sas-and-sata.48/
10 Gbps primer: https://www.truenas.com/community/resources/10-gig-networking-primer.42/
Burn-in and testing: https://www.truenas.com/community/threads/building-burn-in-and-testing-your-freenas-system.17750/
Hard Drive Troubleshooting Guide : https://www.truenas.com/community/resources/hard-drive-troubleshooting-guide-all-versions-of-freenas.17/
Virtualization: https://www.truenas.com/community/resources/absolutely-must-virtualize-freenas-a-guide-to-not-completely-losing-your-data.212/
Is my Realtek ethernet really that bad?: https://www.truenas.com/community/resources/is-my-realtek-ethernet-really-that-bad.196/
Script multi_report.sh : https://www.truenas.com/community/threads/multi_report-sh-version-for-core-and-scale.97451/
