I’m very new to all this but i’m trying to install jellyfin through truenas apps and it keeps showing this error message:
[EFAULT] Failed to render compose templates:
Traceback (most recent call last): File “/usr/bin/apps_render_app”, line 33, in sys.exit(load_entry_point(‘apps-validation==0.1’, ‘console_scripts’, ‘apps_render_app’)()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 48, in main render_templates_from_path(args.path, args.values) File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/render.py”, line 31, in render_templates rendered_templates[i.name] = env.get_template(i.name).render( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 1301, in render self.environment.handle_exception() File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 936, in handle_exception raise rewrite_traceback_stack(source=source) File “/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.21/templates/docker-compose.yaml”, line 17, in top-level template code {% do c1.add_port(values.network.https_port, {“container_port”: values.consts.internal_https_port}) %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File “/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.21/templates/library/base_v2_1_65/container.py”, line 290, in add_port self.ports._add_port( File “/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.21/templates/library/base_v2_1_65/ports.py”, line 114, in _add_port self._check_port_conflicts(port_config, ip.version) File “/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.21/templates/library/base_v2_1_65/ports.py”, line 66, in _check_port_conflicts raise RenderError(f"Port [{host_port}/{proto}/ipv{ip_family}] already added for [{host_ip}]") base_v2_1_65.error.RenderError: Port [8096/tcp/ipv4] already added for [0.0.0.0]
This shoes regardless of if the port number is set to 8096 or 30013.
Does anyone know what this means or how I can fix it??
