Jellyfin NVIDIA Hardware Decoding issues. | TrueNAS Scale 24.10.2
Okay… I’ve installed Jellyfin through the community app, I’ve edited my user_config.yml to include the right UUID for the GPU. And I’ve enabled hardware decoding in the Jellyfin dashboard. But when it tries to transcode to a lower bitrate, it crashes the player and spits out a generic ffmpeg error. I’ve looked at literally everything and I still have no clue.
2025-02-10 19:47:38.391578+00:00[13:47:38] [INF] [30] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for matt2. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
2025-02-10 19:47:38.417877+00:00[13:47:38] [INF] [29] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: Deleting partial stream file(s) /cache/transcodes/2e065d0d545eff6ea99357c006406a54.m3u8
2025-02-10 19:47:38.834765+00:00[13:47:38] [INF] [34] Jellyfin.Api.Controllers.DynamicHlsController: Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
2025-02-10 19:47:38.835465+00:00[13:47:38] [INF] [34] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -f matroska -init_hw_device cuda=cu:0 -filter_hw_device cu -hwaccel cuda -hwaccel_output_format cuda -noautorotate -hwaccel_flags +unsafe_output -threads 1 -i file:"/mnt/media/Movies/Queer (2024)/Queer.2024.2160p.WEB-DL.DDP5.1.Atmos.DV.HDR.H.265-FLUX.mkv" -noautoscale -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 hevc_nvenc -tag:v:0 hvc1 -preset p1 -b:v 7616000 -maxrate 7616000 -bufsize 15232000 -profile:v:0 main -g:v:0 72 -keyint_min:v:0 72 -vf "setparams=color_primaries=bt2020:color_trc=smpte2084:colorspace=bt2020nc,scale_cuda=w=2560:h=1382,tonemap_cuda=format=yuv420p:p=bt709:t=bt709:m=bt709:tonemap=bt2390:peak=100:desat=0" -codec:a:0 libfdk_aac -ac 2 -ab 256000 -af "volume=2" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "689f9da97b8441b5e26b4d01cd1287a8-1.mp4" -start_number 0 -hls_segment_filename "/cache/transcodes/689f9da97b8441b5e26b4d01cd1287a8%d.mp4" -hls_playlist_type vod -hls_list_size 0 -y "/cache/transcodes/689f9da97b8441b5e26b4d01cd1287a8.m3u8"
2025-02-10 19:47:38.888950+00:00[13:47:38] [ERR] [29] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: FFmpeg exited with code 255
2025-02-10 19:47:38.988660+00:00[13:47:38] [ERR] [29] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL GET /videos/5bca925e-bc02-51cb-ae70-d9a4ce220bc1/hls1/main/-1.mp4.
2025-02-10 19:47:38.988768+00:00MediaBrowser.Common.FfmpegException: FFmpeg exited with code 255
2025-02-10 19:47:38.988829+00:00at MediaBrowser.MediaEncoding.Transcoding.TranscodeManager.StartFfMpeg(StreamState state, String outputPath, String commandLineArguments, Guid userId, TranscodingJobType transcodingJobType, CancellationTokenSource cancellationTokenSource, String workingDirectory)
2025-02-10 19:47:38.988883+00:00at Jellyfin.Api.Controllers.DynamicHlsController.GetDynamicSegment(StreamingRequestDto streamingRequest, Int32 segmentId)
2025-02-10 19:47:38.988938+00:00at Jellyfin.Api.Controllers.DynamicHlsController.GetHlsVideoSegment(Guid itemId, String playlistId, Int32 segmentId, String container, Int64 runtimeTicks, Int64 actualSegmentLengthTicks, Nullable`1 static, String params, String tag, String deviceProfileId, String playSessionId, String segmentContainer, Nullable`1 segmentLength, Nullable`1 minSegments, String mediaSourceId, String deviceId, String audioCodec, Nullable`1 enableAutoStreamCopy, Nullable`1 allowVideoStreamCopy, Nullable`1 allowAudioStreamCopy, Nullable`1 breakOnNonKeyFrames, Nullable`1 audioSampleRate, Nullable`1 maxAudioBitDepth, Nullable`1 audioBitRate, Nullable`1 audioChannels, Nullable`1 maxAudioChannels, String profile, String level, Nullable`1 framerate, Nullable`1 maxFramerate, Nullable`1 copyTimestamps, Nullable`1 startTimeTicks, Nullable`1 width, Nullable`1 height, Nullable`1 maxWidth, Nullable`1 maxHeight, Nullable`1 videoBitRate, Nullable`1 subtitleStreamIndex, Nullable`1 subtitleMethod, Nullable`1 maxRefFrames, Nullable`1 maxVideoBitDepth, Nullable`1 requireAvc, Nullable`1 deInterlace, Nullable`1 requireNonAnamorphic, Nullable`1 transcodingMaxAudioChannels, Nullable`1 cpuCoreLimit, String liveStreamId, Nullable`1 enableMpegtsM2TsMode, String videoCodec, String subtitleCodec, String transcodeReasons, Nullable`1 audioStreamIndex, Nullable`1 videoStreamIndex, Nullable`1 context, Dictionary`2 streamOptions, Boolean enableAudioVbrEncoding, Boolean alwaysBurnInSubtitleWhenTranscoding)
2025-02-10 19:47:38.989023+00:00at lambda_method1029(Closure, Object)
2025-02-10 19:47:38.989073+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.TaskOfActionResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
2025-02-10 19:47:38.989146+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask`1 actionResultValueTask)
2025-02-10 19:47:38.989172+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
2025-02-10 19:47:38.989197+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
2025-02-10 19:47:38.989209+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
2025-02-10 19:47:38.989221+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeInnerFilterAsync>g__Awaited|13_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
2025-02-10 19:47:38.989233+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextResourceFilter>g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
2025-02-10 19:47:38.989246+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
2025-02-10 19:47:38.989258+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
2025-02-10 19:47:38.989269+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
2025-02-10 19:47:38.989279+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
2025-02-10 19:47:38.989300+00:00at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
2025-02-10 19:47:38.989307+00:00at Jellyfin.Api.Middleware.ServerStartupMessageMiddleware.Invoke(HttpContext httpContext, IServerApplicationHost serverApplicationHost, ILocalizationManager localizationManager)
2025-02-10 19:47:38.989314+00:00at Jellyfin.Api.Middleware.WebSocketHandlerMiddleware.Invoke(HttpContext httpContext, IWebSocketManager webSocketManager)
2025-02-10 19:47:38.989320+00:00at Jellyfin.Api.Middleware.IPBasedAccessValidationMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager)
2025-02-10 19:47:38.989327+00:00at Jellyfin.Api.Middleware.LanFilteringMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager, IServerConfigurationManager serverConfigurationManager)
2025-02-10 19:47:38.989333+00:00at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
2025-02-10 19:47:38.989339+00:00at Jellyfin.Api.Middleware.QueryStringDecodingMiddleware.Invoke(HttpContext httpContext)
2025-02-10 19:47:38.989346+00:00at Swashbuckle.AspNetCore.ReDoc.ReDocMiddleware.Invoke(HttpContext httpContext)
2025-02-10 19:47:38.989352+00:00at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext)
2025-02-10 19:47:38.989358+00:00at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider)
2025-02-10 19:47:38.989365+00:00at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
2025-02-10 19:47:38.989371+00:00at Jellyfin.Api.Middleware.RobotsRedirectionMiddleware.Invoke(HttpContext httpContext)
2025-02-10 19:47:38.989390+00:00at Jellyfin.Api.Middleware.LegacyEmbyRouteRewriteMiddleware.Invoke(HttpContext httpContext)
2025-02-10 19:47:38.989397+00:00at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
2025-02-10 19:47:38.989417+00:00at Jellyfin.Api.Middleware.ResponseTimeMiddleware.Invoke(HttpContext context, IServerConfigurationManager serverConfigurationManager)
2025-02-10 19:47:38.989424+00:00at Jellyfin.Api.Middleware.ExceptionMiddleware.Invoke(HttpContext context)
2025-02-10 19:47:39.077551+00:00[13:47:39] [INF] [34] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: Deleting partial stream file(s) /cache/transcodes/689f9da97b8441b5e26b4d01cd1287a8.m3u8
2025-02-10 19:47:40.576082+00:00[13:47:40] [INF] [29] Emby.Server.Implementations.Session.SessionManager: Playback stopped reported by app Jellyfin Web 10.10.5 playing Queer. Stopped at 0 ms
OK, all I had to do was reinstall the app.
I had installed the app before I installed the NVIDIA drivers.
