Jellyfin Nvidia Passthrough Problems
Hello everyone.
I hope this is the right place to post this problem and that I am not reposting a problem that has already been discussed (I could not find a similar problem via search).
I have a home-built server running TrueNAS Scale 25.04.1.
I have installed Jellyfin 10.10.7 from the apps section, which has been running stable for some time.
I recently installed an Nvidia T400 graphics card in my system to use it for Jellyfin.
The T400 is recognized without any problems after I installed the NVIDIA drivers.
It is shown in the ‘GPU Configuration’ area of the jellyfin app settings.
My problem is that this error occurs when I check the “Use this GPU” checkbox:
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 562, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 622, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 619, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 294, in nf
    rv = func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 101, in wrapped
    result = func(*args)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 229, in do_update
    app = self.update_internal(job, app, data, trigger_compose=app['state'] != 'STOPPED')
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 259, in update_internal
    update_app_config(app_name, app['version'], new_values, custom_app=app['custom_app'])
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 60, in update_app_config
    render_compose_templates(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 51, in render_compose_templates
    raise CallError(f'Failed to render compose templates: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last):
  File "/usr/bin/apps_render_app", line 33, in <module>
    sys.exit(load_entry_point('apps-validation==0.1', 'console_scripts', 'apps_render_app')())
  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main
    render_templates_from_path(args.path, args.values)
  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path
    rendered_data = render_templates(
  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates
    rendered_templates[i.name] = env.get_template(i.name).render(
  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render
    self.environment.handle_exception()
  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception
    raise rewrite_traceback_stack(source=source)
  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/docker-compose.yaml", line 3, in top-level template code
    {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %}
  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 63, in add_container
    container = Container(self, name, image)
  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/container.py", line 99, in __init__
    self.deploy: Deploy = Deploy(self._render_instance)
  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/deploy.py", line 15, in __init__
    self.resources: Resources = Resources(self._render_instance)
  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 24, in __init__
    self._auto_add_gpus_from_values()
  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 55, in _auto_add_gpus_from_values
    raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")
base_v2_1_35.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]
As far as I can tell, it seems to be an issue with the environment variables to pass the GPU to the Jellyfin docker.
I tried adding an environment variable by hand, which is
NVIDIA_VISIBLE_DEVICES=GPU-91131f1f-23ab-ab92-cdab-c814cb87700f
This also leads to a very similar error.
I have also created “/mnt/.ix-apps/app_configs/jellyfin/values.yaml” and entered this there:
nvidia_gpu_selection:
  "0000:01:00.0":  # PCI-Adresse deiner GPU (lspci bestätigt)
    uuid: "GPU-91131f1f-23ab-ab92-cdab-c814cb87700f"  # deine UUID
It still does not work and the log file (/var/log/middlewared.log) shows this:
[2025/07/01 08:55:53] (ERROR) middlewared.job.run():528 - Job <function CRUDService._get_crud_wrapper_func.<locals>.nf at 0x7fa4daf5ab60> failed: CallError('Failed to render compose templates: Traceback (most recent call last):\n  File "/usr/bin/apps_render_app", line 33, in <module>\n    sys.exit(load_entry_point(\'apps-validation==0.1\', \'console_scripts\', \'apps_render_app\')())\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main\n    render_templates_from_path(args.path, args.values)\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path\n    rendered_data = render_templates(\n                    ^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates\n    rendered_templates[i.name] = env.get_template(i.name).render(\n                                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render\n    self.environment.handle_exception()\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception\n    raise rewrite_traceback_stack(source=source)\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/docker-compose.yaml", line 3, in top-level template code\n    {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %}\n    ^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 63, in add_container\n    container = Container(self, name, image)\n                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/container.py", line 99, in __init__\n    self.deploy: Deploy = Deploy(self._render_instance)\n                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/deploy.py", line 15, in __init__\n    self.resources: Resources = Resources(self._render_instance)\n                                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 24, in __init__\n    self._auto_add_gpus_from_values()\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 55, in _auto_add_gpus_from_values\n    raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")\nbase_v2_1_35.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]\n')
[2025/07/01 08:56:18] (ERROR) middlewared.job.run():528 - Job <function CRUDService._get_crud_wrapper_func.<locals>.nf at 0x7fa4b83b6700> failed: CallError('Failed to render compose templates: Traceback (most recent call last):\n  File "/usr/bin/apps_render_app", line 33, in <module>\n    sys.exit(load_entry_point(\'apps-validation==0.1\', \'console_scripts\', \'apps_render_app\')())\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main\n    render_templates_from_path(args.path, args.values)\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path\n    rendered_data = render_templates(\n                    ^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates\n    rendered_templates[i.name] = env.get_template(i.name).render(\n                                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render\n    self.environment.handle_exception()\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception\n    raise rewrite_traceback_stack(source=source)\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/docker-compose.yaml", line 3, in top-level template code\n    {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %}\n    ^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 63, in add_container\n    container = Container(self, name, image)\n                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/container.py", line 99, in __init__\n    self.deploy: Deploy = Deploy(self._render_instance)\n                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/deploy.py", line 15, in __init__\n    self.resources: Resources = Resources(self._render_instance)\n                                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 24, in __init__\n    self._auto_add_gpus_from_values()\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 55, in _auto_add_gpus_from_values\n    raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")\nbase_v2_1_35.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]\n')
[2025/07/01 09:09:41] (ERROR) middlewared.job.run():528 - Job <function CRUDService._get_crud_wrapper_func.<locals>.nf at 0x7fa498564e00> failed: CallError('Failed to render compose templates: Traceback (most recent call last):\n  File "/usr/bin/apps_render_app", line 33, in <module>\n    sys.exit(load_entry_point(\'apps-validation==0.1\', \'console_scripts\', \'apps_render_app\')())\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main\n    render_templates_from_path(args.path, args.values)\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path\n    rendered_data = render_templates(\n                    ^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates\n    rendered_templates[i.name] = env.get_template(i.name).render(\n                                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render\n    self.environment.handle_exception()\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception\n    raise rewrite_traceback_stack(source=source)\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/docker-compose.yaml", line 3, in top-level template code\n    {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %}\n    ^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 63, in add_container\n    container = Container(self, name, image)\n                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/container.py", line 99, in __init__\n    self.deploy: Deploy = Deploy(self._render_instance)\n                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/deploy.py", line 15, in __init__\n    self.resources: Resources = Resources(self._render_instance)\n                                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 24, in __init__\n    self._auto_add_gpus_from_values()\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 55, in _auto_add_gpus_from_values\n    raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")\nbase_v2_1_35.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]\n')
[2025/07/01 09:14:56] (ERROR) middlewared.job.run():528 - Job <function CRUDService._get_crud_wrapper_func.<locals>.nf at 0x7fa49810ad40> failed: CallError('Failed to render compose templates: Traceback (most recent call last):\n  File "/usr/bin/apps_render_app", line 33, in <module>\n    sys.exit(load_entry_point(\'apps-validation==0.1\', \'console_scripts\', \'apps_render_app\')())\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main\n    render_templates_from_path(args.path, args.values)\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path\n    rendered_data = render_templates(\n                    ^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates\n    rendered_templates[i.name] = env.get_template(i.name).render(\n                                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render\n    self.environment.handle_exception()\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception\n    raise rewrite_traceback_stack(source=source)\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/docker-compose.yaml", line 54, in top-level template code\n    {{ tpl.render() | tojson }}\n    ^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 79, in render\n    "services": {c._name: c.render() for c in self._containers.values()},\n                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 79, in <dictcomp>\n    "services": {c._name: c.render() for c in self._containers.values()},\n                          ^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/container.py", line 418, in render\n    result["environment"] = self.environment.render()\n                            ^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/environment.py", line 109, in render\n    raise RenderError(f"Environment variable [{k}] is already defined from the application developer.")\nbase_v2_1_35.error.RenderError: Environment variable [NVIDIA_VISIBLE_DEVICES] is already defined from the application developer.\n')
[2025/07/01 09:40:54] (ERROR) middlewared.job.run():528 - Job <function CRUDService._get_crud_wrapper_func.<locals>.nf at 0x7fa4981c1d00> failed: CallError('Failed to render compose templates: Traceback (most recent call last):\n  File "/usr/bin/apps_render_app", line 33, in <module>\n    sys.exit(load_entry_point(\'apps-validation==0.1\', \'console_scripts\', \'apps_render_app\')())\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main\n    render_templates_from_path(args.path, args.values)\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path\n    rendered_data = render_templates(\n                    ^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates\n    rendered_templates[i.name] = env.get_template(i.name).render(\n                                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render\n    self.environment.handle_exception()\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception\n    raise rewrite_traceback_stack(source=source)\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/docker-compose.yaml", line 3, in top-level template code\n    {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %}\n    ^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 63, in add_container\n    container = Container(self, name, image)\n                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/container.py", line 99, in __init__\n    self.deploy: Deploy = Deploy(self._render_instance)\n                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/deploy.py", line 15, in __init__\n    self.resources: Resources = Resources(self._render_instance)\n                                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 24, in __init__\n    self._auto_add_gpus_from_values()\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 55, in _auto_add_gpus_from_values\n    raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")\nbase_v2_1_35.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]\n')
[2025/07/01 10:06:05] (ERROR) middlewared.job.run():528 - Job <bound method AppService.redeploy of <middlewared.plugins.apps.app_scale.AppService object at 0x7fa4fdf53e50>> failed: CallError('Failed to render compose templates: Traceback (most recent call last):\n  File "/usr/bin/apps_render_app", line 33, in <module>\n    sys.exit(load_entry_point(\'apps-validation==0.1\', \'console_scripts\', \'apps_render_app\')())\n             ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 48, in main\n    render_templates_from_path(args.path, args.values)\n  File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path\n    rendered_data = render_templates(\n                    ^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 31, in render_templates\n    rendered_templates[i.name] = env.get_template(i.name).render(\n                                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render\n    self.environment.handle_exception()\n  File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception\n    raise rewrite_traceback_stack(source=source)\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/docker-compose.yaml", line 3, in top-level template code\n    {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %}\n    ^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/render.py", line 63, in add_container\n    container = Container(self, name, image)\n                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/container.py", line 99, in __init__\n    self.deploy: Deploy = Deploy(self._render_instance)\n                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/deploy.py", line 15, in __init__\n    self.resources: Resources = Resources(self._render_instance)\n                                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 24, in __init__\n    self._auto_add_gpus_from_values()\n  File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.2.5/templates/library/base_v2_1_35/resources.py", line 55, in _auto_add_gpus_from_values\n    raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]")\nbase_v2_1_35.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]\n')
Does anyone have experience with this type of problem or an idea of what to do in such a case?
This post should have the solution
Thanks a lot! :+1:
