Jinja2 Exception When Installing Photoprism (TrueNAS Scale)
Greetings,
I am trying to install Photoprism on TruNAS Scale ElectricEel-24.10.0.2 but the install fails. Apps > Check Available Apps > Photoprism > Install. Other posts on the forum about Photoprism problems start from a successful install. At 80% progress, I get the following error:
[EFAULT] Failed to render compose templates: Traceback (most recent call last): File "/usr/bin/apps_render_app", line 33, in sys.exit(load_entry_point('apps-validation==0.1', 'console_scripts', 'apps_render_app')()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 47, in main render_templates_from_path(args.path, args.values) File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 36, in render_templates ).render({'ix_lib': template_libs, 'values': test_values}) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render self.environment.handle_exception() File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception raise rewrite_traceback_stack(source=source) File "/mnt/.ix-apps/app_configs/photoprism/versions/1.1.18/templates/docker-compose.yaml", line 72, in top-level template code {% set path = no_scheme.split("/")[1:] %} ^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 485, in getattr return getattr(obj, attribute) ^^^^^^^^^^^^^^^^^^^^^^^ jinja2.exceptions.UndefinedError: list object has no element 1
and expanding more info shows:
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 488, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 535, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *args)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_thread
    return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1361, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 268, in nf
    rv = func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf
    res = f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 203, in do_create
    return self.create_internal(job, app_name, version, data['values'], complete_app_details)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 248, in create_internal
    raise e from None
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 233, in create_internal
    update_app_config(app_name, version, new_values)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 59, in update_app_config
    render_compose_templates(
  File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 50, in render_compose_templates
    raise CallError(f'Failed to render compose templates: {cp.stderr}')
middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last):
  File "/usr/bin/apps_render_app", line 33, in <module>
Please help.
Exact same issue any fix found?
Try using a fully qualified URL under the “Photoprism Configuration” > “Site URL” field. Because this forum blocks me from posting an example URL you’ll just need to add https:// in front of the hostname.
no. I will try the solution from lecturer. Let me know if that works your you.
