What are best practices for monitoring TrueNAS Scale with zabbix?
Should i install and configure zabbix agent standard (apt) way using Linux shell? Or there is better way to do it from TrueNAS GUI with some kind of dedicated app or etc.?
Thres an “Offical” Zabbixtemplate vor TrueNAS Core, it works but its not 100% compatible with Scale. It uses the SNMP Agent.
It should be ootb in Zabbix.
Till now i dindt finde a better template.
Found some custom template. Im atm at testing
https://github.com/tr1plus/zabbix_truenas_SCALE_snmp/tree/main
Thank you very much, this helped me a lot today! ![]()
