Hi all, some help appreciated here.
I’ve done this before but now I’ve allways the error on subject.
Here’s the output command:
root@Server:~# **mount -t nfs -vvvv 192.168.121.3:/mnt/PLUGIN/Armazenamento /mnt/download**
mount.nfs: timeout set for Sat May 3 19:18:54 2025
mount.nfs: trying text-based options 'vers=4.2,addr=192.168.121.3,clientaddr=192.168.121.9'
mount.nfs: mount(2): Operation not permitted
mount.nfs: trying text-based options 'addr=192.168.121.3'
mount.nfs: prog 100003, trying vers=3, prot=6
mount.nfs: trying 192.168.121.3 prog 100003 vers 3 prot TCP port 2049
mount.nfs: prog 100005, trying vers=3, prot=17
mount.nfs: trying 192.168.121.3 prog 100005 vers 3 prot UDP port 45028
mount.nfs: Operation not permitted for 192.168.121.3:/mnt/PLUGIN/Armazenamento on /mnt/download
More info:
root@Server:~# showmount -e 192.168.121.3
Export list for 192.168.121.3:
/mnt/PLUGIN/Armazenamento *
Some info about system
OS Version:25.04.0
Product:MS-7798
Model:Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz
Memory:31 GiB
System Serial:To be filled by O.E.M.
Instances
Autostart: Yes
Base Image: Ubuntu plucky amd64 (20250501_07:42)
CPU: All Host CPUs
Memory: 4 GiB
Secure Boot: No
Trying to share a folder from a truenas scale to a instance.
